Anybody tried this? HM100 > HM700
I'm looking for a small camera for doing news in a more unintrusive way, and I thought of buying the HM100.
Now, I deliver most of my stuff via SDI out from my HM700, so I wondered, if I could record clips on the HM100, and put the SDHC cards into the HM700 and play them out via SDI from the HM700. I would (like to) think, that it would be possible - but has anybody tried it "in real life"? |
I have both cameras and while I haven't gone SDI out of the cameras I have had footage from both cameras on the same card and didnt have any issues when transfering the footage.
The header files names are different so its very easy for me to figure out which camera was which.
John Sirb Lake Breeze Video |
Hi John,
Thanks for the reply. Great - I think that's the way to go, then. Didn't realise that JVC followed another naming convention on the HM100 - strange :-) Regarding the SDI out, that's no problem at all. The HM700 will play out all that can be played IN the cam (LCD screen) via the SDI out - or downconvert it to SD, if one choose so - I do that, as our TV stations still use SD. Thanks for your reply. But BTW - are you satisfied with the HM700 / HM100 combo - how do the output compare in your opinion? /peter |
#4 | |
There may be a way to change that, but the would require cracking the manual :>) As far as the output goes, if the lighting is decent, you might notice a slight difference are I think it's more of a glass issue ( I really wish JVC would have put a tad bigger lens). I would suggest if you dont already have a wide angle for the camera, I would consider adding it, there are some good threads with recommendations already here.
