HM700/790e - what software - FCP, CS5 OR EDIUS ? at DVinfo.net
Go Back   DV Info Net > JVC ProHD & MPEG2 Camera Systems > JVC GY-HM 800 / 700 / 600 Series Camera Systems
GY-HM8xx, HM7xx and HM6xx ProHD camcorders & decks.
Old November 9th, 2010, 09:34 AM   #1
Hi all
I'm looking to buy 700/790 - can't make my mind up - hence need help
also what software is best for the JVC, some say cs5. FCP or edius grass valley, what spec would i need to ensure it all works, do i need a capture card?
Pls help i'm looking to set up in jan 2011
ur advice would be great,,,,,i do asian weddings in uk
Rana Sodhi is offline   Reply With Quote
Old November 9th, 2010, 11:52 AM   #2
IMHO, since use a Mac Pro and a Macbook Pro, I use Final Cut Pro Suite. You don't need anything but a SD card reader for the Mac Pro. I shoot in 720P MOV, so I just plug the card, copy and paste the .MOV files and open FCP, import them and start editing them all in one motion... Do yourself a favor and get high quality SD cards. I use Panasonic 32Gig SDHC Class 10 cards and I've never had a problem.
Steve J. Nordahl
Bethlehem, Pa.
Steve J. Nordahl is offline   Reply With Quote
Old November 10th, 2010, 09:01 AM   #3
The HM700 does indeed deliver what it promises with Final Cut Studio. No deck, no capture card, no firewire, just get a cheap USB2 card reader that can handle SDHC cards, and drop your raw footage right into Final Cut's timeline.
Daniel G. Trout
Fishmonger Media Consulting
Daniel Trout is offline   Reply With Quote
Old November 11th, 2010, 01:03 PM   #4
Although I currently own CS5 and FCS, Premiere Pro never gets opened. With my 700, it is basically 100% Final Cut workflow. A 10$ card reader and a very specced Mac Pro or iMac will do just fine. Believe me, FCS has more then enough tools within it to handle anything you can throw at it. ( except Blu-Ray =/)
JVC GY-HM700u
www.dumbluckltd.com
Stephen Dougherty is offline   Reply With Quote
Old November 11th, 2010, 08:14 PM   #5
I've been editing on Edius for 4 yrs and have no issues at all with editing MP4 from the 700 on it
John Sirb
Lake Breeze Video
John Sirb is offline   Reply With Quote
Old November 11th, 2010, 08:47 PM   #6
I've also read, (I can't remember where, so if someone could confirm or deny I'd be very greatful,) that the upcoming open source release of LightWorks, (EditShare - The Smart Way to Edit Together - Home) will natively support the "Final Cut Pro" friendly Quicktime-wrapped XDCAM files from the 700 as well, so no passing it through Sony or JVC's intake software necessary.
This was pretty good news to me, as it opens up my options on inexpensively expanding my post-production arsenal to include non-Macs without changing the cameras file setup.
EDITED TO ADD: Silly me. I read it on the link I posted above in the LightWorks specifications. Straight from the horses mouth!
Daniel G. Trout
Old November 13th, 2010, 07:29 AM   #7
Just to add another hat into the ring, It's as simple as the FCP workflow if you shoot with .mp4 and edit with Sony Vegas.
James McBoyle is offline   Reply With Quote
Old November 14th, 2010, 05:23 AM   #8
Editing with Edius 5 Capture and storage useing the the supplied software, that way when you open the clips, just drag them into the edius project bin
Mick
Mick Jenner is offline   Reply With Quote
Old December 9th, 2010, 03:05 PM   #9
I use FCS. It's great for the drag and drop option, although i've found it easier in the long run to use a Prores sequence instead of the XDCam sequence (No Mpeg Reconforming then)
Casey Krugman is offline   Reply
  You are here: DV Info Net > JVC ProHD & MPEG2 Camera Systems > JVC GY-HM 800 / 700 / 600 Series Camera Systems
