Downconvert to SD at DVinfo.net
Go Back   DV Info Net > JVC ProHD & MPEG2 Camera Systems > JVC GY-HM 800 / 700 / 600 Series Camera Systems
GY-HM8xx, HM7xx and HM6xx ProHD camcorders & decks.
Old August 6th, 2010, 12:10 PM   #1
Downconvert to SD
If I record 1280x720P and send out via firewire (DV) will the scenes be Progressive or Interlaced?
Ron Edwards is offline   Reply With Quote
Old August 8th, 2010, 10:38 AM   #2
Downconvert to SD
If you set youFirewire output to DV, then your camcorder will transmit DV-compliant bit stream, whcih is interlaced (NTSC or PAL).
Joachim
Joachim Claus is offline   Reply
  You are here: DV Info Net > JVC ProHD & MPEG2 Camera Systems > JVC GY-HM 800 / 700 / 600 Series Camera Systems
