HM700 and Canon 5D question at DVinfo.net
Go Back   DV Info Net > JVC ProHD & MPEG2 Camera Systems > JVC GY-HM 800 / 700 / 600 Series Camera Systems
GY-HM8xx, HM7xx and HM6xx ProHD camcorders & decks.
Old April 19th, 2010, 11:18 AM   #1
Greetings. I have shot footage with my HM700 in 720p60 HQ. It edits great in FCP. I want to add some additional footage from the Canon 5D. I saw that canon released the plugin for log and transfer in FCP, but does it transcode it to only prores? if so, will it play smoothly in the XDCAM EX timeline that was created when i started editing the JVC footage? The XDCAM EX time line works great, I hope I dont have to transcode everything to prores. Thanks for any advice you all may have.
-Travis
Travis Bush is offline   Reply With Quote
Old May 14th, 2010, 04:43 PM   #2
Hi Travis,
wouldn't converting the canon-media to a xdcam ex-codec, using compressor, be a valuable option?
But, hey, why not give it a try first, they just might play together nicely.
Frank Feijen is offline   Reply With Quote
Old May 15th, 2010, 01:49 PM   #3
Hey Travis,
Set your Final Cut sequence to render to ProRes 422 if you're editing XDCAM EX (even if you haven't converted your HM700 footage to ProRes 422 yet). Convert your DSLR stuff to ProRes for editing. That mixes nicely in the timeline. There's no reason to convert your DSLR stuff to XDCAM EX -- that's merely a shooting format.
I'd recommend always setting your timeline to render to ProRes 422 if you're working with XDCAM EX, rather than rendering to XDCAM EX. Quality will be marginally higher, but your render times will be much faster.
Ryan Mast is offline   Reply
  You are here: DV Info Net > JVC ProHD & MPEG2 Camera Systems > JVC GY-HM 800 / 700 / 600 Series Camera Systems
