Thread Tools
Search this Thread
Uncompressed from HM700?
Has anyone captured footage from the HM700 via the HDSDI output? Possibly to a NanoFlash or AJA KI Pro or directly to a computer via one of the popular SDI capture cards?
Just wondering how the noise issues are via that route.
Boycott Guinness, bring back the pint!!! |
Bear in mind that these things are still not "uncompressed".
Steve |
A live feed from the HD-SDI output can be considered "uncompressed" with respect to the fact that it has not gone through the mpeg2 encoder, however it is still chroma-subsampled to 4:2:2 at 8 bits/pixel.
If you digitize this live signal using an uncompressed codec then (in theory) the resulting media will an exact pixel for pixel clone of the original HD-SDI signal. I have done some tests with the uncompressed codec as well as the Apple ProRes codecs and they are available in the FCP forum. But what about noise? The mpeg2 encoder isn't actually adding video level noise at the compression stage. Yes there will be added compression artifacts (and chroma is sub-sampled to 4:2:0) but if anything you will probably see slightly less overall noise in the B & R channels after encoding because the of the added amount of subsampling. This difference is negligible and difficult to see even when carefully analyzing the separate channels. The latest HM700 firmware update addressed noise reduction (among other things) but I have yet to empirically analyze a before and after.
Tim Dashwood |
Tim,
Does all of that also apply to the HM-100? I have asked JVC directly several times with, predictably, no response. |
#5 |
Tim, I was under the impression the output on the HDSDI is 10bit. Not so?
#6 |
#7 |
Paul, I am also interested in the output from the HM100 HDMI port. I am thinking of getting a blackmagic card.
I found this link on the JVC US page. http://usjvc.com/faq/index.php?actio...123&artlang=en It states HDMI is produces uncompressed output. I am not sure this is official. |
#8 |
Thanks very much Andy; I overlooked that JVC page. I guess the CD nanoFlash would also be an option. The nano would also add timelapse to the humble HM-100 -- although at quite a price!
#9 | |
JVC America
Craig Yanagi - National Marketing Manager JVC Professional Video Division, JVCKENWOOD USA Corp. |
#10 |
Craig, thank you for clarifying this. I am going to move forward with my plans to get a blackmagic card.
Tim, seems this should be in a FAQ or sticky. |
