Does the HM700 come with a AB Power Tap? at DVinfo.net
Go Back   DV Info Net > JVC ProHD & MPEG2 Camera Systems > JVC GY-HM 800 / 700 / 600 Series Camera Systems
GY-HM8xx, HM7xx and HM6xx ProHD camcorders & decks.
Old August 14th, 2009, 12:00 PM   #1
Can anyone tell me if the GY-HM700u has an Anton Bauer "power tap" incorporated into its Anton Bauer battery mount? This is usually used to power a sun gun to the top of the camera. Thanks!
Jon Springer is offline   Reply With Quote
Old August 14th, 2009, 12:38 PM   #2
Yes it does. It is a standard AB Gold Mount plate.
Tim Dashwood
Old August 14th, 2009, 02:00 PM   #3
Awsome news. Thanks Tim.
Old August 14th, 2009, 03:06 PM   #4
Yes it does have a "D"-shaped two-pin connector on the main battery mounting plate, and a little power switch down underneath the main plate (good to know in advance!). I just used it last night with a rented Litepanels Mini LED spotlight, and it worked fine.
Bob Richardson is offline   Reply With Quote
Old August 14th, 2009, 03:57 PM   #5
Further to the switch: this decides whether or not the D-Tap provides power all the time OR just when the record section is engaged. This is a good way to keep the light off when not in actual use (ie. recording, not in standby)
Old August 15th, 2009, 07:34 AM   #6
Just as an FYI the European HM700, which comes with an IDX plate, also has a power tap socket available.
James McBoyle is offline   Reply With Quote
Old August 15th, 2009, 04:00 PM   #7
Which poses the question - is it possible to get a European HM700 with a AB Gold mount? I run AB power and am curious. There obviously are adapter plates but as I discovered using one on the back of a DSR450, they are a weak point that would better be eliminated...
Cotty
Steve Cottrell is offline   Reply With Quote
Old August 16th, 2009, 01:44 AM   #8
you can change the plate from V-Mount to AB-Plate. Thats no problem.
Eric Deyerler is offline   Reply
  You are here: DV Info Net > JVC ProHD & MPEG2 Camera Systems > JVC GY-HM 800 / 700 / 600 Series Camera Systems
