imac and hm700 at DVinfo.net
Go Back   DV Info Net > JVC ProHD & MPEG2 Camera Systems > JVC GY-HM 800 / 700 / 600 Series Camera Systems
GY-HM8xx, HM7xx and HM6xx ProHD camcorders & decks.
Old June 8th, 2009, 06:20 PM   #1
imac and hm700
anybody know if a imac duo core 1 2ghz 2gb ram will process the 35mbps 720 or 1080 smoothly in final cut pro 6? Would I get dropped frames because of low ram or low speed?
Amos Kim is offline   Reply With Quote
Old June 8th, 2009, 06:29 PM   #2
The processing will be fine (rendering, output, etc.) but you will likely drop frames here and there while playing back 35mbps at the full framerate/dimensions, which isn't a big deal while offlining.
You can turn on dynamic playback for frame rate or pixel dimensions (or both) to compensate for any bottlenecks in your system.
Tim Dashwood
Old June 8th, 2009, 07:20 PM   #3
currently I get dropped frames on the canvas in my final cut pro two-up arrangement when I use 1080p 19mbps.
  You are here: DV Info Net > JVC ProHD & MPEG2 Camera Systems > JVC GY-HM 800 / 700 / 600 Series Camera Systems
