split screen effect at DVinfo.net
Go Back   DV Info Net > JVC ProHD & MPEG2 Camera Systems > JVC GY-HM 800 / 700 / 600 Series Camera Systems
GY-HM8xx, HM7xx and HM6xx ProHD camcorders & decks.
Old June 4th, 2009, 10:04 PM   #1
split screen effect
I, despite having such a lowsy run with the drop out issue with the HD 101, am considering the HM 700. Has anyone who has owned or operated a HM 700 seen any evidence of the split screen effect which has been in evidence in the HD series? Does anyone know whether JVC has actually engineered a solution for the split screen effect in the HM 700?
regards
Ian Skurrie
Ian Skurrie is offline   Reply With Quote
Old June 4th, 2009, 11:00 PM   #2
The design of the CCDs is exactly the same (2 x 480x720 chips,) but the split-screen was an issue that was taken care of back in 2006 by a revamped QC. Obviously some HD100 or 200 series cameras slipped through the cracks but we seldom hear of this problem on the GY-HD board now.
You asked if anyone has seen evidence of it. I have... under extreme circumstances (available light on my residential street at 2-3AM with +9dB gain and gamma cranked up.)
You can see for yourself if you download my night tests.
http://www.dvinfo.net/conf/jvc-gy-hm...ior-tests.html
If the slight appearance of the "split-screen" can only be invoked under these extreme conditions then I would say the issue has been resolved on JVC's end.
Tim Dashwood
Old June 7th, 2009, 11:55 PM   #3
Thanks Tim, from your test footage, for all practical purposes, I would think that the problem is resolved, which is good news.
regards
Ian Skurrie
Old June 8th, 2009, 02:39 AM   #4
I have been using a 100(a) for over 3 years now and have not had a split occur in actual shooting conditions, including available light work documentary-style in offices, large not well lit meeting rooms etc. with window or just high up room lights which can be pretty dull.
I can produce it on demand by putting the camera under my desk with no or little light where the combination of low light + low contrast will bring it out due to not enough information for the cpus to calibrate and balance.
But under the conditions of real work it has never happened.
Les Howarth is offline   Reply With Quote
Old June 8th, 2009, 07:06 AM   #5
I have a HD110, and I CAN get it if I record before the unit warms up and have the gain +9 or higher. Once it's warmed up though even on max gain, it usually dissapears. But I rarely gain over +9 anyway.
In fact I've noticed that that (horrors!) the AGC (is that right or am I using the terminology from the HD10?) when I select it as my max gain, gives a suprisingly good image (usually better than my low light level tweaking) at super low light scenes where I have no control over lighting. Again, when it was warmed up the split screen dissapeared ALWAYS on the auto gain circuit.
So I'm sure you could force a new HM700 in the first 5 minutes to show split screen, otherwise I'm assuming (I don't have a HM700 yet) we wouldn't have any problems.
Alex Humphrey is offline   Reply
  You are here: DV Info Net > JVC ProHD & MPEG2 Camera Systems > JVC GY-HM 800 / 700 / 600 Series Camera Systems
