wireless receiver mount plate for HM700? at DVinfo.net
Go Back   DV Info Net > JVC ProHD & MPEG2 Camera Systems > JVC GY-HM 800 / 700 / 600 Series Camera Systems
GY-HM8xx, HM7xx and HM6xx ProHD camcorders & decks.
Old May 23rd, 2009, 11:17 AM   #1
Curious if the legacy accessory plates from the GY-HD series for mounting drive/wireless next to the battery mount are good for the HM700. It would appear that it's the same battery back plate. I'll be sticking with A/B mount this time, and haven't found an appropriate way to mount my lectro 411 when handheld. On a tripod, it's been OK to bungee it to a leg.
Sean Adair - NYC - www.adairproductions.com
JVC GY-HM-700 with 17x5 lens, MacPro 3.2ghz 8-core, 18gb. (JVC HD200 4 sale soon)
Sean Adair is offline   Reply With Quote
Old May 27th, 2009, 08:07 AM   #2
Anton/Bauer sells several components which work perfectly with the HM700 and Lectrosonic wireless mic receivers. They are:
a. Universal BP Back Plate: Goes between the back of the camera and the A/B Gold Mount. I believe it's the same plate used by the GY-HD series of JVC cameras.
b. ABWMK-Kit Universal Mounting Plate: Attaches to the right angle flange of the Universal BP Back Plate.
c. Lectrosonics Wireless Receiver Holders which attach to the ABWMK-Kit (three models):
WRB-185
WRB-200
WRB-201
Each of the above models accommodates different Lectrosonics receivers. I have a Lectro UCR-210D wireless receiver and it works perfectly with the WRB-200. I suggest you contact Anton/Bauer to find out which holder works best with your receiver.
Steven Auerbach is offline   Reply With Quote
Old June 10th, 2009, 08:50 AM   #3
I have made an adapter plate for my Sennheiser Radio receiver on the card side of the HM700 and found out that the receiver is picking up RF noise from the camera. I tried mounting it alongside the mic inputs but the RF noise seemed to worse. I had to adjust the squelch on the receiver to compensate for the noise which leaves the signal distance of the transmitter lower. Anybody else had this problem?
Gregory Murphy is offline   Reply With Quote
Old June 15th, 2009, 08:01 AM   #4
Sean, I recently had to use a sennheiser wireless for scouting images at a rock concert. Crowded and all. Cam handheld.
I used the good old velcro solution on my 251 and imagine this would also work on the 700: Sony battery-velcro-EK 3041-velcro-DRHD100. Secured with two thick rubber bands. No problem whatsoever. Receiver powered via teletest cable. Of course you wouldn't need the HDD.No noise, no interference.
Velcro strips are about 2 inch wide, 3 long.
Claude Mangold is offline   Reply With Quote
Old June 15th, 2009, 08:23 AM   #5
I used velcro and straps on my hd200 as well, but never like attaching it to the battery. I may make a second generation homespun rig again for a detachable side plate to hold the lectro. The commercial A/B solutions are bulkier and pricier than I'd like.
If you remove the battery mount plate, you can sandwich in an aluminum tab, and rig a small lateral plate to this for velcro and strap.
Old June 16th, 2009, 09:46 PM   #6
Found the perfect solution for my G2 wireless receiver, which has a "shoe" to mount on a camera; The Flash Shoe, a $9 gizmo that screws into the hole in the middle of the handle and provides a flash shoe receiver for the shoe of the receiver mount.
On the label it says "Manfrotto" in the background, and says:
143S
DlAH AHOW, 1/4" MAL
E ATTCHMNT
I got mine at Kennedy's here in the Dallas, Ft. Worth area
KENNEDY's ENG, INC.
Here's a picture... look at the middle of the carrying handle:
http://newsvideo.com/shoe.jpg
Don Smith
NewsVideo.com
Donald Smith is offline   Reply With Quote
Old June 17th, 2009, 06:02 AM   #7
Boy, I must have been on CRACK when I wrote my previous message!
Here's the correct information:
143S
FLASH SHOE, 1/4" MAL
E ATTCHMNT
Yes, I'm spelling "ATTCHMNT" correctly. That's how it is on the label. :)
Don Smith
NewsVideo.com
  You are here: DV Info Net > JVC ProHD & MPEG2 Camera Systems > JVC GY-HM 800 / 700 / 600 Series Camera Systems
