GY-HM Resolution? at DVinfo.net
Go Back   DV Info Net > JVC ProHD & MPEG2 Camera Systems > JVC GY-HM 800 / 700 / 600 Series Camera Systems
GY-HM8xx, HM7xx and HM6xx ProHD camcorders & decks.
Old April 3rd, 2009, 10:21 AM   #1
GY-HM Resolution?
Anyone have any ideas about how the HM700 camera performs on the resolution charts?
Kenn Christenson is offline   Reply With Quote
Old April 3rd, 2009, 01:56 PM   #2
I just got the 17x5 Fujinon lens in my hands so I'll run resolution tests this weekend.
Tim Dashwood
Old April 3rd, 2009, 03:19 PM   #3
Thanks, Tim.
I've got a project with a fair amount of match moving, involved, and this looks like the highest res CCD camera in the sub $10K range.
Old April 3rd, 2009, 03:52 PM   #4
If you download some of the demo footage, there's an overcranked shot of two kids running in the forest. It tracks quite well in Syntheyes.
David Petersen is offline   Reply With Quote
Old April 3rd, 2009, 04:22 PM   #5
Thanks, David. I must have missed that one.
So far it's been between the EX1 and the HM700. I like the EX1's resolution and low noise, but I'm a little concerned about the skew/wobble factor, especially since there will be some hand-held match move shots - similar to this video test: YouTube - Through A Glass, Darkly - Patrol
Old April 3rd, 2009, 08:10 PM   #6
I've basically written off CMOS sensor cameras for that reason. I know it's still trackable, but the track error can be quite large and you can get slipping. The other biggie is if you track and stabilize the footage - with the rolling shutter you'll end up with jellocam.
I've been considering the HMC and HPX since they seemed to be the best CCD cameras out, but they are a bit soft at full 1080 resolutions. And I wanted tapeless and no HDV... Then JVC announced the HM700 and it seems like the perfect camera for my needs, although a little more expensive.
Old April 3rd, 2009, 08:47 PM   #7
That's been my thinking, as well. I work with both the HVX200 & HPX500 - both are pretty soft, to my eyes. Looking forward to Tim's chart - should, hopefully, answer that question
Old April 4th, 2009, 11:12 PM   #8
I've talked to Russ Andersson (Mr Syntheyes) at Siggraph and he seems to be absolutely down on CMOS based cams because of the jello-cam (rolling shutter) effect on tracking accuracy. On the other hand, I'm not sure he's ever tried a cam as good as the latest from Sony or Panny.
Old April 5th, 2009, 10:09 AM   #9
Have you seen video from the new Panasonic HPX300? There's no way (in 1080p24 at least) you'd be able to get an acceptable track out of that footage - every time the camera changes directions during a pan the entire background jellos from one side to the other.
Check out (esp. the background around 0:37 in): HPX300 with Super16 Adapter Footage | CineTechnica
I'd take him as a good source of info for the tracking stuff. If you're heavy into 3d tracking the fact of the matter is the CMOS cameras just aren't going to cut it in every shooting situation. You just can't have the rolling shutter artifacts and get the mathematic precision required for 3d tracking.
Old April 5th, 2009, 11:22 AM   #10
Strange isn't it, that the human eye can adapt to this kind of footage and feel like it's a great picture, but the computer is completely blown away.
It seems that CMOS has almost totally become the technology of choice for this class of camera, and it has a lot going for it - low light performance, sensor site density, etc.
There just seems to be this "one small problem" for those who also want to use the camera for match moving footage.
Old April 5th, 2009, 11:37 AM   #11
Well at least the manufacturers have a bunch of options out now! Low light and noise may be a dealbreaker for some, so the EX-series is great for them. Long-GOP compression for others, so the HPX and HVX are great for them. I'm just happy JVC's coming out with this camera - removable lenses, inexpensive media, XDCAM compression, shoulder form factor, and CCDs. You might almost think they thought, "Hmm, what would happen if an EX3, HD250, HPX170, and HMC150 had a child..."
I am eagerly awaiting the resolution test results, though, to see how the new spatial offsetting helps resolution.
Old April 5th, 2009, 12:04 PM   #12
Yes, I'm delighted that JVC didn't just jump on the CMOS bandwagon. I just worry about the future of the CCD based cameras in this market space. Hopefully technology will eventually find a way to deal with the rolling shutter issues.
I just worry that camera makers think of match moving as something done by Hollywood studios with big budgets, not by independent guys with small pockets, and thus don't weight it heavily in making decisions about technology in this segment of the market.
Old April 6th, 2009, 07:35 PM   #13
I have an EX1 (CMOS rolling shutter) and I hope that the HM100 has good enough image quality to match with it. The EX1 image is beautiful and the wobble isn't noticeable unless you have special needs, ie tracking or computer steadicam, in which case the 'jello' effect is apparent. I do hope that future CMOS evolves where this isn't an issue because it seems that the manufacturers are going in this direction.
Keith Moreau is offline   Reply With Quote
Old April 6th, 2009, 07:45 PM   #14
Rumor is, around 900 lines - we'll see. Tim Dashwood was going to try and shoot a resolution chart.
Old April 7th, 2009, 02:12 PM   #15
Done. http://www.dvinfo.net/conf/jvc-gy-hm...ion-tests.html
Tim Dashwood
Tim Dashwood is offline   Reply
  You are here: DV Info Net > JVC ProHD & MPEG2 Camera Systems > JVC GY-HM 800 / 700 / 600 Series Camera Systems
