Editing JVC HM100 and Panasonic GH1 Footage? at DVinfo.net
Go Back   DV Info Net > JVC ProHD & MPEG2 Camera Systems > JVC GY-HM 150 / 100 / 70 Series Camera Systems
GY-HM150, HM100, HM70 recording AVCHD MP4 & QuickTime .MOV to SDHC cards.
Old December 23rd, 2010, 03:06 PM   #1
I'm looking at picking up a small camcorder to use alongside/intercut with my GH1 (soon to be GH2).
The obvious choice is the Pana HMC40, but sometimes I need to deliver to my main client in PAL format (50i specifically, although I just delivered in 25P and they were okay with it). That said, I wouldn't mind being able to have the option of shooting for broadcasters in the Americas.
So the HMC40 not being NTSC/PAL switchable is a strike against it unfortunately. The HM100, on the other hand, is switchable.
I currently transcode the .mts files to Prores and edit in FCP.
I'll also post this on the GH1 board.
Thanks all!
Dave Mercer is offline   Reply With Quote
Old December 25th, 2010, 04:23 AM   #2
HM100 for PAL/NTSC
Dave,
the HM100 would definitely be a very good choice. Especially as you work in Final Cut Pro. The HM100 record format can be set to Quicktime file format. Having set this, you can immediately import the video clips into your FCP project by drag and drop - no transcoding or long lasting import process is necessary.
And, the HM 100 can be switched to 50Hz (PAL countires).
Joachim
Joachim Claus is offline   Reply With Quote
Old December 27th, 2010, 06:34 PM   #3
THanks for the reply.
However, I don't think I stated my question properly.
I'm more interested in how I'd edit footage from the GH1 and HM100 in the same timeline ...
Old December 28th, 2010, 08:06 AM   #4
I am not a FCP user. With Media Composer Version 5 you can mix clips with different formats in one timeline, i.e. not onlydifferent resolution but also different framerate.
Joachim
Old December 30th, 2010, 04:06 PM   #5
Thanks. Appreciate the reply,
  You are here: DV Info Net > JVC ProHD & MPEG2 Camera Systems > JVC GY-HM 150 / 100 / 70 Series Camera Systems
