HM100 and smaller cameras? - Page 4 at DVinfo.net
Go Back   DV Info Net > JVC ProHD & MPEG2 Camera Systems > JVC GY-HM 150 / 100 / 70 Series Camera Systems
GY-HM150, HM100, HM70 recording AVCHD MP4 & QuickTime .MOV to SDHC cards.
Old October 14th, 2009, 02:06 PM   #46
What would happen if you dropped 1080i50 HDV and 720p50 footage from the HM100, onto a 720p50 timeline, with FCP? I've never tried it, but I bet it would work fairly well with Edius. (I haven't touched a Mac in decades, and have no idea what you can do with FCP.)
Robert M Wright is offline   Reply With Quote
Old October 14th, 2009, 02:28 PM   #47
Again, there is no PAL version - idiots!
But I have run out of time, so I have ordered two of the Aiptek AHD Z500 plus cameras, plus a waterproof case (mainly for amusement!) as it does 1280 x 720 (same as the HM100) at 60fps.
60fps should convert to 50fps with the minimum amount of pain that I can get away with all things considered.....
Many thanks for the tip Robert, I had never heard of Aiptek before, and the price is half that of the Sanyo I was looking at, so although I'm sure the quality will be lacking in many areas, I will be able to strap one to the chassis whilst driving across rivers and not have to worry about losing an expensive camera. It doesn't matter too much about the quality of the shots, as long as the crocodiles show up.
Huge amounts of thanks to Bob as well, who without his test footage would never have gotten me started with playing around in FCP and mixed timelines (have been googling alot!) at a time when I have plenty of mechanical things to sort out etc etc
Thanks guys, lets hope it works out ok!
www.aiptek.eu - PocketDV AHD Z500 PLUS
John McDonald is offline   Reply With Quote
Old October 14th, 2009, 02:31 PM   #48
You create a new timeline sequence in fcp at a set size/frame rate. You add some footage at that size/frame rate. Then when you try to ad anything else, it asks if you want to convert to the sequence settings. If you say yes, it converts(?) using prores.
Very easy really, but I have no idea how this effects things down the line......!
Old October 14th, 2009, 04:16 PM   #49
Might be worthwhile to get your hands on some 1080i50 footage, and experiment a little bit.
Old October 14th, 2009, 05:30 PM   #50
John, a reporter from a local station used Aiptek while shooting a story, looked OK, even for broadcast. I am sure they had to tweak the footage, but really while watching a story for 3 minutes I did not even think about the quality. Just remember you probably should not use over 20-30% shot with such cam.
Robert Rogoz is offline   Reply With Quote
Old October 18th, 2009, 10:59 AM   #51
If it were me, I'd certainly prefer to deinterlace and downsize 1080i50 to 720p50, than convert 1080i60 to 720p50. I don't know what's available on a Mac, but with a PC I know I can do the 1080i50 to 720p50 conversion pretty nicely (at least with most any typical footage) without a whole lot of hassle. Taking 1080p60 (or 720p60 to 720p50 though, would require either simple (crude) frame decimation (which can make for less than ideal judder - little jumps every 5th frame - ok for some footage I suppose, but not so great for other types of footage, like slow panning for example) or getting a heck of a lot more involved with frame interpolation (like with something akin to Magic Bullet or something like that).
  You are here: DV Info Net > JVC ProHD & MPEG2 Camera Systems > JVC GY-HM 150 / 100 / 70 Series Camera Systems
