July 17th, 2007, 07:49 PM | #16 |
I just did the upgrade and checked the new firmware versions
VTR 122 ENC 113 All is good! It was kinda scarry watching the LCD visuals. It looks like it's broken when performing the upgrade! I have a shoot next week so I'll let you know how the capture goes. I use AIC so I haven't had the problem with the gaps between clips but I have had some long wedding ceremony clips with cuts in the middle. I've been using the "DVHSCap/MpegStreamclip" method as a work around for these problem clips but it is very time consuming so I hope this is the end of those problems! |
July 18th, 2007, 08:54 AM | #17 |
is it compatible with euro version? 100e.
Many thanks |
July 18th, 2007, 11:08 AM | #18 |
Not compatible with the E models. Cameras sold in th US only, according to JVC website.
July 18th, 2007, 03:10 PM | #19 |
I don't think the Euro dudes had problems because the 25 frames vs the US's 24.
I actually had problems updating and now the camera won't reboot. The camera has has Timecode issues since day one. (there is a drift in timecode when recording to editing systems - whether it is Final Cut, Liquid, or Premiere - all the latest versions) It had been to the factory and they failed to fix it. They suggested the firmware upgrade. During this upgrade, the screen went nuts. I waited a few minutes to see if it would reboot. It didn't. I waited some more. Seven minutes went by and I thought I should try turning it off and restarting it. The power switch wouldn't turn it off. So I unplugged it. Now it won't reboot. So, it's off to the factory again. So it may be that whatever was originally wrong with my camera caused difficulties in flashing. I don't know. But.. be careful. |
July 18th, 2007, 05:39 PM | #20 |
DUDE! You were supposed to wait about 8 minutes. Didn't you read the directions?
When the audio LED's start to flash together at 1-second intervals, the upgrade is complete. Then you're supposed to pull out the SD card and the camera reboots itself. Edited to add: People, unless you are having Final Cut Pro capture issues, it's probably best not to update your firmware. Firmware is the heart of your camera. It's not something you mess around with for sh*t's & giggles. To perform the upgrade you must follow very specific instructions to obtain the correct upgrade version, then you must meticulously follow the directions correctly to load the new firmware into your camera. As you can see, one guy already messed his camera up. Bummer! |
July 18th, 2007, 10:54 PM | #21 |
The instructions for my update said TWO minutes. I waited much longer than that before removing the card and it never rebooted.
But... It's with JVC now. So... we shall see. |
July 30th, 2007, 04:25 AM | #22 |
So here is an update!
I have good news, I just captured 2 hrs. of footage from a wedding I did last night. There are NO SPLITS in any of my clips! Not even on the long ceremony clip which was over 27 minutes. I am used to having at least 2-3 clips per tape that require me to re-capture w/DVHScap but this is the first time I haven't had to use it! It appears the upgrade is working great. Note: I captured using AIC, but I tested the HDV codec also. If you use HDV, you will still have those 2-3 second gaps between clips, but you shouldn't have splits in the middle anymore. |
July 30th, 2007, 06:08 AM | #23 |
Any UK/Europe HD*** user confirm whether this is applicable to us and if so whether this helps (AIC isn't an option for us)?
I guess I should phone IVC Europe later in the day. Cheers. |
July 30th, 2007, 06:42 AM | #24 |
Second David's request as to whether there is an update for the E model. The E model has exactly the same FCP issues in segmenting clips.
Rob |
July 30th, 2007, 04:56 PM | #25 | |
JVC in Sydney have just advised me that a new firmware update became available for PAL cameras about two weeks ago. If you check with JVC support in WA, they should be able to help you. In Sydney, they advised that JVC Australia don't release the firmware for self-installation. It has to be loaded at a service centre. Cheers Glenn |
July 30th, 2007, 06:52 PM | #26 |
Thanks, Glenn.
Great news - but living in Fremantle, I hope that this does not mean that I have to send it all the way to Sydney! Rob |
July 31st, 2007, 02:00 AM | #27 |
Cheers Glen....probably differs in the UK also so I'll call JVC today.
Thanks. |
July 31st, 2007, 02:31 PM | #28 |
I am just tired of the effing camera breaking my tape up into separate clips during import in FCP. It is annoying, and a major time waster when I have to work with footage that way. Having 6000 clips in my bin is a major pain in my ass. JVC, you need to wake up and fix that so 1 Tape = 1 tape in my bin.
Yes I have the box unchecked in FCP for break on scene detection. I import with iMovie so I can have 1 file for 1 tape and then re-sync the audio in FCP. I should not have to do this, I should be able to dump a tape into 1 clip like the Sony DVCAM tape I import, or other Sony cameras. I am never buying another JVC product again and hate this effing camera. Just last week my LCD goes apeshit and wont display any information on it anymore, right n the middle of a shoot, plus I have a dead pixel now, and the damn camera ate 4 new tapes. I have the wonderful 110U, and it went to JVC for a firmware update 2 months ago. |
July 31st, 2007, 04:44 PM | #29 | |
Dead pixels just need to be mapped out. I have owned sony, canon, and ikegami, all had dead pixels (along with other problems). At least with the JVC, you can deactivate those nasty pixels. I hope your able to get your JVC problems ironed out. I know how it feels to have faulty equipment....its like my life. Jonathan P.S. - A DTE drive makes life so effing nice :)
Florescent tungsten hovered under cubicle design |
August 1st, 2007, 04:36 AM | #30 | |
I can understand you're frustration. I still think the HD100 series gives you the best picture for a 5K budget. |
