I used two different kinds of tapes. Will my camera die? at DVinfo.net
Old July 15th, 2007, 12:19 AM   #1
I don't know how many times I've been told "don't use different tapes, especially not ones with different kinds of lubricants." Well, last night, in the heat of the moment, I let a "consumer level" Sony tape slip into my virgin Panasonic-Master-Quality-Only HD100, without even cleaning the heads first.
What to do? I've read that cleaning the heads now can jam all the gunk together more.
Do I stick to the new, slick Sony? Go back to my trusty, betrayed JVC? Get a head cleaning?
Andrew Hasse is offline   Reply With Quote
Old July 15th, 2007, 12:51 AM   #2
Hello
if you can afford it
you should get a DR HD100 no more tape worries
i don't think one tape should hurt.
I think the camera will let you know if the heads need to be clean
JOE
Joseph A. Benoit is offline   Reply With Quote
Old July 15th, 2007, 06:59 PM   #3
I generally use those cheap Sony DVC tapes. They won't hurt the camera at all.
If I'm shooting for someone else, I just use whatever tape they give me.
It's recommended to stick to one brand but not critical.
Scott Jaco is offline   Reply With Quote
Old July 16th, 2007, 12:10 AM   #4
Andrew, where did you hear that using a head cleaner can cause those difficulties. I think most people have reported that using a head cleaner in your circumstances is a good way to go.
rob
Robert Castiglione is offline   Reply With Quote
Old July 16th, 2007, 06:50 AM   #5
If tape is the only medium you are recording to, then I think it is very critical to make sure you don't gum up the heads.
If you (or your client) don't care if you can never replay your footage, then I suppose it isn't critical.
Tim Dashwood
Old July 16th, 2007, 10:28 PM   #6
The heads will need cleaning eventually no matter what type of tapes you use.
