Upset with JVC Service at DVinfo.net
Old July 11th, 2007, 09:27 PM   #1
Well.
I took my camera in on June 11th for the dead firewire port issue and finally got it back today, July 11th, only to find that my SD Card slot no longer works. What is that about? It's like I traded off one port for another.
I hesitate taking it back to them for them to have it for another month. Anyone have any ideas of what kind of home remedies can be done for this? I tried buying a new SD card, but that didn't work.
Thanks.
Heath Vinyard
www.ghostlandmedia.com
Heath Vinyard is offline   Reply With Quote
Old July 11th, 2007, 10:25 PM   #2
Did you format the card? You might think it's not working if that's the case.
Warren Shultz is offline   Reply With Quote
Old July 12th, 2007, 09:34 AM   #3
Thank you for the reply. I tried to format the card through the camera multiple times, on all 3 SD cards I have, and each time I get the Error "No card." Is this the way you suggest? I'm open to anything right now. :)
Just as a side note, before I took the camera in, I never had an issue with the SD Card port. I wonder if it's a firmware upgrade that was done?
Thank you.
Heath Vinyard
Old July 12th, 2007, 12:57 PM   #4
Images: 1
Thank you.
Heath, there 'may have' been a cable or connector inadvertently left unplugged during re-assembly. I've been guilty of that a few times in all the years I worked as an equipment maintenance technician.
I would call and calmly advise them of what has happened and ask for expedited repairs since you feel this problem was induced during the original repair process.
-gb-
Old July 12th, 2007, 07:23 PM   #5
Heath, which camera/model do you have? And how did your FW port get fried? If you don't mind me asking.
Brian Ladue is offline   Reply With Quote
Old July 12th, 2007, 10:35 PM   #6
I have the HD100u with the A upgrade. The DR-100 firestore stopped working with the camera and at that point, I couldn't even dump footage from tape. That part of the camera is working great now, and I purchased a no power firewire cable, just in case.
Heath Vinyard
Old July 13th, 2007, 09:53 PM   #7
Thanks Heath, so was it the Firestore that caused the problem or would it have been your computer?
Old July 14th, 2007, 08:39 PM   #8
Well, I'd have to assume it was the firestore connection that caused it, but it was really me hot swapping the device and not the device itself.
Heath Vinyard
