JVC vertical mounting ??? at DVinfo.net
Old July 1st, 2007, 10:08 AM   #1
I've been using the JVC HD110 for awhile and love it. my latest ambition is to shoot some rising smoke but have the camera vertical to take advantage of hdv 16:9, like pictured below:
http://www.pohlvideo.com/temp.jpg
but now i found this in the manual (pg. 6):
"Use the unit in an upright position.
If placed on its side, heat release efficiency will deteriorate,
adversely affecting the tape transport. Depending on cir-
cumstances the tape may also be damaged"
so... what's a good way of doing this? it will be indoors but perhaps keep a fan blowing on it? ice pack? should it face "tape side" or "lcd side" up? anyone try this before with success?
Ben Pohl is offline   Reply With Quote
Old July 1st, 2007, 11:43 AM   #2
I've never tried this, and I'm not a JVC rep, so use this advice at your own risk. But, if it were my camera I would get a good fan and have it blow over the rear portion of the camera during the shoot. If I had a fan on it I wouldn't worry about any heat problems. Without a fan, I'd be really concerned.
I've felt the back of the unit under normal shooting conditions and it really heats up so I think the manual is right and you would ruin the tape at the very least.
Ben
Ben Lynn is offline   Reply With Quote
Old July 1st, 2007, 11:43 AM   #3
i think its ok if its not prolonged shoot. otherwise tether to your computer or dte and use those instead of tape. You wont be using the transport that way.
Ted Ramasola is offline   Reply
