#16 |
Well, I have to admit that I am confused. Pixels are the most fundamental elements in digital imaging, how can I get my head around pixels? I am from graphics background, sorry if I am asking ignorant questions here about video cameras.
#17 |
I thought that shooting 24p gives better quality per frame since the camera uses repeat flags rather than 2:3 pulldown. Can someone explain this once and for all?
#18 | |
The same holds true for HD camcorders. It's not about resolution. Again: 720p and 1080i HDV camcorders are recording the *same* amount of information to tape. The choice between 720 progressive vs. 1080 interlace has less to do with the number of pixels than it does with the motion signature and other image aesthetics plus the camera's form factor, ergonomics, price range, application, workflow, feature sets and a number of other considerations. Hope this helps, |
#19 | |
HDV Cinema
60p, of course, doubles the frame rate and the data that needs to be encoded. But, the GOP length doubles from 6 to 12 which compensates. The encoder is also much better in the HD200HD250. Bottom-line -- it isn't going to make any difference what frame rate you choose in terms of quality. It's a matter of the look you want. This is a matter of taste.
Switcher's Quick Guide to the Avid Media Composer >>> http://home.mindspring.com/~d-v-c |
#20 |
The other thing to think about is the limitations of 1/3" chips and lens optics at this price point. There seems to be a certain limit as to how much detail can be resolved from the current crop of HDV cameras even if they can do progressive scan video. Take the Panasonic HVX200 for example. This is a true 1080p camera but the chips use pixel shift on 960x540 pixels. While pixel shift is a great way to get extra detail it is not perfect and you will never get a solid 1920x1080 pixels of detail.
What number of pixels a format records is different then what the camera itself can resolve. Think of a flatbed scanner for example. You could scan a 4x6 photo at 300dpi or 1200dpi. While the 1200dpi will have more pixels there isn't really any more detail to the image then the 300dpi version. So while a 1080p lower cost camera may have more pixels the extra pixels might end up being a little overkill and end up resolving the same amount of detail in the image. All of this is of course in theory and somewhat true depending on the camera. The newer 1080 cameras that have true 1080p do seem to have a tiny edge in detail over 720p. It is not a lot however and you have to ask yourself if the extra processing for 1080p video is worth that very tiny edge in detail. Now if we were talking a Cinealta camera then maybe there would be a lot of extra detail but any 1/3" camera I have seen is only going to have a tiny edge in detail if any at all. If your focus is not dead on then any edge the 1080 camera had is out the window. |
#21 | |
"The Canon XL H1 CCD block is interlace, not progressive, therefore the 30fps and 24fps frame rates cannot be referred to technically as 30P and 24P. However, 30F and 24F from the XL H1 appear almost indistinguishable from 30P and 24P, as they are basically the same results as progressive scan, but produced by different means. When the XL H1 is set to Frame recording, the CCDs are actually clocked at 24 frames per second. The video signal remains at 24fps as it is passed from the CCD block to the baseband LSI, and through the HD Codec LSI. Only when it reaches the recording output stage is it resampled to 60i via a 3:2 pull-up method." |
#22 |
That's right, the container is 720p60, so 24p has 36 repeated frames while 30p has 30. That doesn't exactly add up to a 20% difference in quality as some may initially believe. I remember seeing some real-world tests a while back and there was no difference in quality between JVC HD100 24p and 30p that couldn't be explained by shutter rate. At the same shutter, the picture was the same. Does anyone know where to find that test, or other tests that disagree?
software engineer |
#23 | |
Since the time that I first put that article together, Canon has released more information detailing how Frame mode works. In the very near future, DV Info Net will host a once-and-for-all in depth explanation of Frame mode, but for now, what's important to understand is what I said in my post above: Canon's 24F Frame mode does indeed provide 24p output. Period. Those who doubt this are urged to capture 24F video with the latest version of Final Cut. Guess which capture setting is used -- 1080 HDV 24p! Final Cut cannot distinguish any difference between 24F and 24P. As far as it's concerned, and for all intents and purposes, 24F is 24P. It doesn't matter that the CCD block is native 1080i. The CCDs are actually clocked at 24 frames per second and what comes out of them is the same results as progressive scan. There is a slight cost of vertical resolution in this process which is negligible and a complete non-issue for all but the most chronic and habitual of measurebators. Hope this helps, |
#24 | |
Ok, thanks for the info. Makes more sense now. I read some articles a few months back on the canon frame mode, less in depth, but still walked away thinking interlaced or interlaced+. What's the reason with Canon not just labeling it as progressive then, if the camera outputs progressive...? |
#25 |
Canon didn't disclose how Frame mode works until November 2006, so anything you read that was written prior to that time has only been speculation. If they had actually called it "progressive," it probably would have caused quite a stir since it is first and foremost a 1080i camera. But in the process I think they created more confusion than they've prevented.
#26 | |
HDV Cinema
"The CCDs are actually clocked at 24 frames per second and what comes out of them is the same results as progressive scan." Plus, "There is a slight cost of vertical resolution." If they clock the chips at 24fps and all 1080-lines are output, so output is "the SAME results as progressive scan" then how do they/you explain the "slight cost of vertical resolution." What causes this loss? The explanation for the loss of V. rez. -- which you agree exists -- is that only 540-lines are output at 24fps. One 540-line field is one field -- and is not a frame. And, this is the reason Canon didn't call it 24p. No matter how often you deny it -- 24F is type of "field-doubled" video and not true 1080p24. There is no need for measurebating. It's been measured and the numbers published for all to read. And, it's measured resolution shows it to not be 1080p24. It's about 540-TVL/ph on "dynamic" video. NOTE: "field-doubled" -- contrary the negative reactions by Canon owners is not a negative description. It is a factual description. There are many ways it can be done. Some are crude "line-doubling" while others are very sophisticated and can increase apparent V. rez to more than 540-lines. Canon, obviously does it very well. (However, these processes work best on still images, not moving images. And, video is mostly motion.) Moreover, the fact Apple named THEIR preset "24p" means nothing about the process by which the video was obtained from the CCDs. It also says nothing about the actual resolution of the video from the Canon.
#27 | |
I'm guessing then that 720p50 would not merely be the 25p film look but with "adequate progressive temporal resolution" but more akin to interlaced footage....which is where I'm missing something. You obviously know the hd100 inside out and are a fan, but I personally can't see a reason to choose this camera if it were not for the true 24p/25p true formats? Has there been any 720p50 footage posted on these boards? I'd be very interested in seeing this. Our soaps over in the UK are all shot interlaced - they altered one to a film look once (it looked like they had de-interlaced the footage) - it just didn't work at all (probably alienated tons of viewers and they soon changed it back). Same if the news were shot 'film style'. Blair Witch works very well because of the 'live' camcorder format used (David Lynch's Inland Empire works well in this format also) but then something like the Exorcist, shot on film, really gets under my skin...it had to be shot in film. There are some terrible judders in films/tv shows shot in film (was watching a bit of ER at breakfast the other morning - if you take your eye of the subjects the background is pretty dizzy). I presume real film has to be 24p but the likes of Varicam, HDCAM and say a viper (Zodiac being the most recent film I can think of) - will they continue to use a 24p rate of more the likes of 60p? If I ever need to look for a second camera then I'd just have to retain the film look but also have the flexability to shoot for different visual requirements (HD250 and a 1080i would be probably tick those boxes perhaps). Forgive me if I've got the wrong end of the stick here, but this intrigues me very much. |
#28 | |||||
We're striving for technical accuracy here. Frame mode does not work the way that you seem to think it does. It works instead the way it was explained in detail in New York last November. The publication for which you write, Digital Content Producer, was invited to attend that press conference. You most certainly would not still be clinging to the false notion that it's "field-doubled" had you been there. Quote:
If it wasn't, then you couldn't use a 24p capture setting to get Frame mode video into the editor. But that much should be quite obvious. |
#29 | ||||
HDV Cinema
Why then, is resolution lost? As I remember, these CCDs do Row-Pair summation INSIDE the CCDs. Which is perfect when outputting interlace. But, if it can't be turned OFF for "progressive" mode -- then there will be about a loss of 25% V. Rez. If I remember, that's about the number you have stated. So, I can think of an explanation that fully matches your description. So, I'm not saying you are wrong! HOWEVER, I can't explain why Canon tried to hide this and why they were willing to create heat by calling it "F" since, if I'm correct, it is "P." Why would they have done this? Waiting on a patent? Quote:
I have not a single email or document from Canon -- other than their several refusals to explain 24F. Nor did they invite me to their NYC meeting. In fact, searching the DCP website, the only comment I can find is from Dave Leitner's H1 review: "Canon has chosen not to divulge how the camcorder captures 24F and 30F." So, perhaps, Canon never invited ANYONE from DCP! Mike has Dave's email and he has mine. If Canon really cared about getting the facts out -- they've had over a year to do so. Quote:
The way the sensors work before encoding has nothing to do with MPEG-2 encoding, recording, NLE capture, disk storage, NLE decoding.
#30 | |
HDV Cinema
720p60 or 720p50 = 1080-lines of vertical information every 1/60th second.
