More Capture problems Vegas 7.0 at DVinfo.net
Old June 23rd, 2007, 01:06 PM   #1
Just got a used HD100, and I'm not able to capture anything in Vegas 7.0 Platinum. The computer will not recognize the camera. Firewire switch is set to DV. When I turn the camera on the computer doesn't acknowledge it. Can I check anything in the Control Panel to see if the camera is being recognized? (I'm trying to capture from tape, not from video.)
Could it perhaps be a blown firewire port? If so, how can I tell if that is the problem?
Last edited by George Huczek; June 23rd, 2007 at 01:36 PM. Reason: More details added
George Huczek is offline   Reply With Quote
Old June 23rd, 2007, 04:36 PM   #2
Hello
are you shooting in SD OR HD
JOE
Joseph A. Benoit is offline   Reply With Quote
Old June 23rd, 2007, 07:45 PM   #3
Originally Posted by Joseph A. Benoit View Post
Hello
JOE
I'm shooting in HDV-HD24P. I tried changing the firewire switch to HDV, (camera off) and it made no difference.
Old June 23rd, 2007, 08:09 PM   #4
can't understand that. Try shooting SD and see if VEGAS will capture it.
maybe the FW port is dead
joe
Old June 24th, 2007, 07:58 AM   #5
I have Vegas 7 on two computers. On my laptop, I've never had a capture problem. On my desktop, it wouldn't recognize the HD100 in SD or HDV. I realized that the desktop computer was behind on Windows updates (wasn't even up to Service Pack 2), so I let it update, and then all was well. Might be worth looking into whether your computer is up to date.
Josh Meredith is offline   Reply With Quote
Old June 24th, 2007, 08:32 AM   #6
Not sure what Vegas 7 "Platinum" is as I do not believe there is such an application. Are you perhaps using Vegas Movie Maker or something?
Also, when you hook up the camera, you should see an icon appear in your tray (by the clock) that may appear and disappear for a quick moment. You can also check device manager in control panel -> system and your IEEE device should show up in there. If Windows detects it, then it's either Vegas or a setting in the camera. If Windows doesn't detect it, than it's either Windows or the camera.
Jon
Jon McGuffin is offline   Reply With Quote
Old June 24th, 2007, 09:35 AM   #7
Jon
Yes, it's Vegas Movie Studio. I expect that the problems I'm having are just due to inexperience! I will keep at it and see what happens. Thanks to you who replied with suggestions.
Old June 24th, 2007, 12:49 PM   #8
I've noticed that after updating the frameworks, everything works good on capture for HDV. I've never had a problem with Vegas 7, it actually works much better for me than premiere pro 2.0 on native capturing. When I first installed PP2 I couldn't capture HDV to save my life. After installing the frameworks updates, it worked flawlessly. Bottom line, go to microsoft's website and do your updates!
Carlos Rodriguez is offline   Reply With Quote
Old June 24th, 2007, 01:43 PM   #9
Hello George
If you could get yourself a DR HD100
no more worries about dumping tape to the computer
just check out the threads on the DR HD100
Joe
