Questions About the Manual at DVinfo.net
Old June 16th, 2007, 10:09 PM   #1
I am going through the manual for the GY-HD100U and have a few questions that from reading it that I cannot find or just did not understand.
1. On page 3 I see that it says that 24p has a 2:3:2:3 pulldown and converts to 60 frames. Is this the reason my video player (mplayer) tells me the footage is 59.95 fps and plays it at double speed?
2. The manual refers to a couple of acronyms that I could not find a definition for: EE and ALC
Thanks for the help. I just finished playing with the iris in manual mode with the ND Filters and the shutter speed mixed with the zebra to control my exposure :)
Oh and I experimented with Macro! Really cool setting :)
Chris Cherrett is offline   Reply With Quote
Old June 17th, 2007, 07:54 AM   #2
Yes, but mplayer should not play it at double speed. It should play the m2t at 59.94 fps, which is normal speed. Your 24P will still look like 24P, as it should.
If you would like to remove the pulldown for editing, you can use a program like Mpegstreamclip and enter 23.98 as the frame rate for the conversion to quicktime.
EE refers to the "passthru" mode on VTRs and cameras, as opposed to PB mode (playback from tape.) EE essentially means that the output is exactly the same as the input, and is not delayed by tape (or confidence heads.)
I'm not sure, but I think the acronym refers to "entry exit?"
ALC means Automatic Level Control.
All references to "timecord" in the manual should actually read "timecode!"
Tim Dashwood
Old June 17th, 2007, 04:15 PM   #3
Thank Tim! :)
As for the pulldown I really don't know what that means so I will start to research it.
Thanks again.
