I was able to play the JVC HDV on the Sony HDR-HC5 at DVinfo.net
Old May 27th, 2007, 09:25 PM   #1
Hello,
I was at Circuit City last Friday looking for a DV camera to use as a deck.
Well, I put the regular 4:3 DV tape that I recorder with the jVC GY-HD110U in the Sony HDR-HC5 and it worked fine(no surprise). Then I put the HDV tape 30P that I recorder with the jVC GY-HD110U and i was able to view it.
The Sony HDR-HC5 LCD said playing HDV 720p on the screen.
Here is the link.
http://www.circuitcity.com/ssm/Sony-...oductDetail.do
Regard,
Jose
Santos Ramos is offline   Reply With Quote
Old May 27th, 2007, 10:03 PM   #2
Sony's will playback HDV1 footage via analog but not firewire.
Useless.
Scott Jaco is offline   Reply With Quote
Old May 27th, 2007, 10:18 PM   #3
What about the HDMI?
Old May 28th, 2007, 02:28 AM   #4
I have no idea. I don't really understand why firewire is not supported, if they went through all the trouble of making the cameras capable of reading both tape formats.
Old May 28th, 2007, 03:38 AM   #5
HDV Cinema
Yes -- via hdmi is supported. All except 720p24.
Old May 28th, 2007, 09:05 AM   #6
720p60 ?!?!
Sean Adair - NYC - www.adairproductions.com
JVC GY-HM-700 with 17x5 lens, MacPro 3.2ghz 8-core, 18gb. (JVC HD200 4 sale soon)
Sean Adair is offline   Reply With Quote
Old May 28th, 2007, 01:17 PM   #7
Does anyone know or think that capturing 30p footage through this camera's HDMI would help, or eliminate the dropped frames/timecode problems that occur through the firewire port?
Ben
Ben Lynn is offline   Reply With Quote
Old May 28th, 2007, 06:01 PM   #8
HDV Cinema
From my REVISED "JVC ProHD Handbook" -- Compatibility with 1080i Camcorders
Recent 1080i HDV camcorders feature an HDMI port. Most, if not all, of these camcorders will playback 720p HDV tapes through their HDMI port. If you play a 720p25, 720p30, 720p50, or 720p60 tape—the camcorder’s transport will play the tape and decode the 720p 4:2:0 signal and output a 4:2:2, uncompressed 720p signal via HDMI.
Because JVC’s 720p24 uses Repeat Flags—not 2-3 pulldown—720p24 ProHD tapes cannot be played back through a 1080i camcorder’s HDMI port.
Unfortunately, 720p video data is not output via the camcorder’s i.LINK port. The i.LINK port can, however, be used for camcorder VTR control.
Since you are bypassing the FireWire for the video signal, the capture will not have issues IF the capture problems are caused by "bad video data."
When you use FireWire control of a camcorder along with HDMI capture, IF the capture problems are being generated from VTR control (TC, etc.) via FireWire, then the problems won't go away.
In other words, HDMI will only cure capture problems only IF they come from the data and not the VTR control (TC, etc.).
However, the "capture problem" may not exist with these 1080i camcorders.
Bottom-line, it depends on the real cause of "capture problems."
Old May 28th, 2007, 06:49 PM   #9
Thanks for the information Steve. I've lost enough hair because of the jvc time code/capture breaks and I'm ready for some type of solution. I love my 100U but I'm very dissappointed with the workflow. A small camera that could possibly bypass the problem would help in post and also serve as a second b roll cam.
Ben
Old May 28th, 2007, 11:01 PM   #10
Is there some type of box that converts HDMI to firewire? I could capture with the new ProRez codecs to keep the files small.
Old May 29th, 2007, 04:44 AM   #11
HDV Cinema
You can't capture to ProRes 422 except with the AJA ioHD which has a hardware encoder chip.
Old May 31st, 2007, 11:03 PM   #12
Contributor
Were you specifically referring to that workflow, because my understanding is you can capture to ProRes 422 with the latest Octomacs and to some of the lighterweight ProRes versions on IntelMacs? Did I get a some bad info?
John Mitchell is offline   Reply With Quote
Old May 31st, 2007, 11:53 PM   #13
HDV Cinema
Maybe you can with the OctoMacs. Please don't assume I'm right on this point.
Old June 2nd, 2007, 11:16 PM   #14
Does this mean that shooting 24p on the JVC results in less compression artifacts than shooting 30p? Since it's using all the bandwidth for fewer frames?
I would think repeat flags are better than 2-3 pulldown for this reason.
