GY-HD100 and DR-HD100 HDV Sync at DVinfo.net
Old May 22nd, 2007, 12:45 AM   #1
Hi guys wondering if you can help with some basic setting.
We have just moved from SD to HDV and are shooting in HDV 25P, but now it seems the timecode on the DR-HD100 doesnt sync with the GY-hd100s tape.
Everytime we pause the camera and then restart record the timecode on the DR-HD100 returns to zero.
Is this the case with HDV or have we got to reset control and fuction settings? (we have set camera to Syncro mode in 1394 Rec Trigger menu)
If we cant sync the timecode is there anyway we can make it so the timecode doesn't go back to zero each time the camera pauses and continues from where the TC stopped?
thanks in advance
Nick
Nick Breen-Kurucsev is offline   Reply With Quote
Old May 25th, 2007, 07:11 AM   #2
Hi Nick,
I don't (yet!) have a DR-HD100, but it is designed to sync with time-code through the FW. What is your time-code generation setting? I would assume regen is appropriate. There are several menu settings that have to be set correctly on the unit as well.
Sean Adair - NYC - www.adairproductions.com
JVC GY-HM-700 with 17x5 lens, MacPro 3.2ghz 8-core, 18gb. (JVC HD200 4 sale soon)
Sean Adair is offline   Reply With Quote
Old May 31st, 2007, 11:09 PM   #3
Contributor
http://www.timdashwood.com/DRHD100
A tutorial by the ever helpful Tim Dashwood - you must have timecode on the DR-HD100 set to external but follow all the settings for best results. Oh you may want use.m2t instead of Quicktime depending on your NLE (use QT if yoou are using FCP only I think)
John Mitchell is offline   Reply
