Recording PAL DV with HD100U - Page 2 at DVinfo.net
Old May 4th, 2007, 07:19 PM   #16
Originally Posted by Jemore Santos View Post
Wow, so there is an actual "J" model, I seriously thought my camera was a "U" model even though the logos on my camera actually say "Victor" instead of JVC.
7.5%? whats that?
I have always had the ability to shoot in both full 60Hz and 50Hz modes, HD, SD and in DV. Recently I upgraded the firmware from work, but is exactly the same in function.
That's pretty amazing, Jemore.
How did you manage to update the firmware?
I presume you're not in a position to share the NTSC-J firmware with the rest of us?
Michael Hurley is offline   Reply With Quote
Old May 4th, 2007, 07:29 PM   #17
Mike, I actually bought this camera when I was living in Japan, and all along I thought my camera was a "U" camera because this was an NTSC region, When I relocated to Sydney I also thought there was no way to shoot in PAL DV because the brochure said so, but I played with the settings and I managed to get PAL DV50i setting, I recently upgraded the firmware because of the white blemish from my camera, the engineer from work managed to upgrade my system FPG settings to the latest version. This has not effected any functions of my camera, I have always had NTSC and PAL capabilities.
"eyes through a digital world"
Jemore Santos is offline   Reply With Quote
Old May 5th, 2007, 05:36 AM   #18
Hey Jemore,
Apologies for not posting back last night - the whole of dvinfo.net seemed to go down.
Sure must be great having both PAL and NTSC in the same box. It really isn't a biggie for me, but the ability to have a PAL DV cassette immediately available after a shoot would be handy for some of the corporate work I do.
When you say 'I played with the settings' and you got the PAL 50i setting - did this involve something out of the ordinary like a combination of button pushes? Or was the PAL DV setting there already and available from the REC section of the menu?
All the best.
Michaell
Old May 5th, 2007, 07:00 AM   #19
Hey Michael, straight out of the box with the options available to me, I seriously thought that this wasn't out of the norm, hmmm, I work for a rental company here and I'm going to have a look at the HD101e for the option of DV60i, and also the HD200/250.
Old May 5th, 2007, 11:58 AM   #20
Good stuff, Jemore.
Look forward to seeing where this goes.
Old December 24th, 2007, 12:46 PM   #21
Hey Tim
I shot video using 50/25 HDV SD50P, Can this be converted to PAL?
Thanks.
Originally Posted by Michael Hurley View Post
Thanks, Tim.
That was my initial understanding also, ie. the PAL formats you could shoot on a HD100U are HDV based only - 720P25 and 576P50.
I was hoping someone had found a workaround to acquire PAL DV directly (50i to tape) perhaps through changes to the firmware, etc.
Hopefully, Jemore can let us know how he enabled it on his 100U.
Thanks everyone for your input.
Michael.
Carl Martin is offline   Reply With Quote
Old December 26th, 2007, 03:19 PM   #22
Yes. Capture the footage using DVHSCap. Then use MPEG Streamclip to convert into PAL Quicktime movies. Just set the Frame Rate box to 25 in MPEG Streamclip.
David Knaggs is offline   Reply
