HD200 Series Scene File Recipes - Page 2 at DVinfo.net
Old May 11th, 2007, 07:10 PM   #16
No I haven't reduced detail because I find that with the mini35 it makes it worse. The detail is already less with the mini35, so reducing it further made it worse in my opinion. Unless you have other thoughts.
Duke
Visit me and my work at www.artofduke.com
Brian Duke is offline   Reply With Quote
Old May 11th, 2007, 07:22 PM   #17
Duke
I was just worried about what the extra edge enhancement might do to the ground glass grain. I haven't conducted any detail tests with the mini35.
If you are watching everything on a HD monitor and it looks good to your taste then don't change anything mid-stride.
I actually sent you an email before you started principal photography suggesting that you not compress the blacks so much, and maybe bring up the master black up in the bleach bypass setting. I'm not sure if you got it.
I was just concerned that you might be cutting down shadow detail unecessarily. You can always easily crush the blacks in post, in a controlled environment.
Are you comfortable shooting WYSIWYG with the bleach bypass scene file? Has your DP had any situations where it wasn't working as well as you'd like?
When in doubt about white clipping, try exposing for the hi-lights and then turn off black compress to obtain some more details in the mid-range.
Tim Dashwood
Old May 14th, 2007, 02:02 AM   #18
Good job
Hi Tim,
Well done on the scene files. I'm doing some test footage on the 250 for JVC Australia this week to show the camera off a little and will definately put a few of these settings to work.
Well done and thanks for the work you've put in on them.
Matt Norman is offline   Reply With Quote
Old May 14th, 2007, 09:37 PM   #19
THE MAN HAS COME THROUGH AGAIN!
Thanks Tim...
Hayes Roberts is offline   Reply With Quote
Old May 15th, 2007, 07:41 AM   #20
Thanks Tim. I tried the files, and they are great. Really appreciate it.
Carl
Carl Martin is offline   Reply With Quote
Old May 24th, 2007, 02:53 AM   #21
Has anyone tested the 'warm green' and got some material to show how it turns out? We're going to do a videoclip pretty soon and I'm looking for a look simular to the 'Amelie' look.
We get the camera (using a hd111e (we're in Europe) on a friday afternoon and will be shooting saturday early, indoors and outdoors, so there isn't much time to test the different settings
www.wanah.nl
Djee Smit is offline   Reply With Quote
Old May 24th, 2007, 10:05 AM   #22
The fifth sample in this test is the "Warm Green" setting.
Right-Click and Save from this link (38.9MB) to view a transport stream that includes comparison tests of:
1. Superwide
2. DSC CDM28 Calibrated
3. Film Noir
4. Warm
5. Warm Green (Amelié)
6. Bleach Bypass (Saving Private Ryan)
7. Cross-Processed Color Reversal (Three Kings)
8. Film Vert (The Matrix)
9. Close-Up Film Vert
10. Close-Up Cross-Process Color Reversal
11. Close-Up Bleach Bypass
12. Running guy Bleach Bypass
Note: This mpeg2 transport stream has not been re-compressed or colour corrected in any way. Only in-camera DSP was used to achieve the "looks." These tests were shot with the Fujinon 13x3.5mm lens, even though the scene files were designed with the 16x5.5mm.
Tim Dashwood
Old May 25th, 2007, 02:07 AM   #23
when I 'save as' I just get a small 8kb .ts file, which I can't play. How can you play this file (on a mac)?
*edit* it works.. thanks, looks great
www.wanah.nl
Old May 25th, 2007, 08:34 AM   #24
use correct scene file for camera
Djee, you probably figured this out, but since you posted in the NEW HD200 settings thread, be sure that you get and use the settings for the HD100/110, since the cameras have completely different processing and settings.
The 100 settings are easy to find in the first post of the sticky thread:
http://www.dvinfo.net/conf/showthread.php?t=62835
Sean Adair - NYC - www.adairproductions.com
JVC GY-HM-700 with 17x5 lens, MacPro 3.2ghz 8-core, 18gb. (JVC HD200 4 sale soon)
Sean Adair is offline   Reply With Quote
Old May 25th, 2007, 11:05 AM   #25
Thanks for mentioning, because I hadn't even thought about that.
www.wanah.nl
Old July 15th, 2008, 09:57 AM   #26
Scene Recipes
Any new Recipes for the 200? Find any 'truer colours'?
I just got a new jvc gyhd200 and im looking for the best colour adjustment I can put on it..
Jonathan Rosenberg is offline   Reply With Quote
Old August 20th, 2008, 06:08 PM   #27
I want to thank Tim for these scene files. Thanks to them (and Paolo Ciccone's TrueColor) I can't get enough of shooting with this camera!
The interesting part for me is whether to shoot with the Superwide scene vs. the DSC setting. Obviously, Superwide provides you with the maximum ability to grade the color later in post to find the look you are after... but what if DSC (or Paolo's TrueColor) is the look you are after in about 80% of the material you shoot?!
I guess it is a good problem to have.
Great work!
jpb
John-Paul Bonadonna is offline   Reply With Quote
Old August 20th, 2008, 06:43 PM   #28
Great work!
If you want the maximum dynamic range with calibrated colour then just use the DSC setting you like, max out black stretch and lower the knee to 80%
Tim Dashwood
Old September 1st, 2008, 04:36 PM   #29
Tim,
I have to shoot a commercial in a controlled environment.I am planning to use your Superwide scene. Is there any way to decrease the noise level in post? The master will be in SD 16/9, is this noise as obvious as I see it on my LCD HD monitor?
Thank you for your great work,
Eugen
Eugen Oprina is offline   Reply With Quote
Old September 9th, 2008, 01:16 PM   #30
Pal - Ntsc
Tim,
I'm mighty grateful for your considerable efforts. I want to buy your DVD as soon as the Pal version is available. In the meantime, I note that you say setups for a NTSC monitor. How do these settings work out in PAL or the 201e versions? The main difference (apart from DV being the frame rate.
Anyway, thank you again, it's all very much appreciated.
Stuart
Paris, France
Stuart Nimmo is offline   Reply
