Anton Bauer on JVC HD111E at DVinfo.net
Old March 14th, 2007, 02:50 PM   #1
Hi, everybody
I need help.
I had JVC HD101E for more than one year with Anton Bauer batteries and everything worked fine. I sold the camera keeping the AB batteries and bought a new JVC HD111E (got it yesterday). Inserted adapter, attached fully charged battery and nothing happened. Checked the camera from AC and small JVC battery – everything worked normal.
Have anybody got an idea what it could be? Did anybody experience the similar problem?
Thank you.
Nicholas Sherman, ACS
Nicholas Sherman is offline   Reply With Quote
Old March 14th, 2007, 02:56 PM   #2
Images: 10
have you put a voltmeter across the battery adapter connections to the camera? There's a fuse within the mount plate that blows, sometimes.
Old March 14th, 2007, 06:07 PM   #3
I had the same problem and the problem was that the AB adapter plate was not making good contact.
In my case, the adapter plate had a chip broken off on the part that hold the plate to the back of the camera.
You might make sure the plate is installed exactly correctly and the contacts are clean.
Old March 15th, 2007, 04:45 PM   #4
Thank you guys for fast response.
As I founded out there are modifications in battery part in JVC HD111E. So, old mount plate won't work on HD111E (different size of contacts). Anton Bauer is aware of it and I have to get today a different version of the mount plate and see what will happen. To my biggest surprise JVC representative in Australia did not know about it. I learned about this problem from Anton Bauer people in Sydney who seems to be more knowledgeable.
I will keep you posted.
www.nsherman.info
Old March 15th, 2007, 06:20 PM   #5
re Anton Bauer Mount Plate
Attention to everybody who has JVC HD101E with Anton Bauer Mount Plate.
In case you want to use this plate on new JVC111E this one won't work. You should upgrade to modified version of the plate.
I just received a new plate from Anton Bauer (Sydney) and it works perfectly.
New plate is absolutely the same except much bigger contact plates size.
Thanks to everybody who tried to help me.
Kindest regards from Down Under
www.nsherman.info
Old March 16th, 2007, 05:34 AM   #6
Nicholas,
You didn't hear anything about the IDX plate did you? Mine seems to work fine on both the HD101 and the HD111.
Mike Marriage is offline   Reply With Quote
Old March 16th, 2007, 02:43 PM   #7
IDX versus Anton Bauer
Mike,
It is a matter of personal choice.
Having experience in using both Anton Bauer and IDX systems, I found Anton Bauer more suitable to my needs and requirements. Also Anton Bauer has excellent service in Australia and price is very compatible.
Cheers,
www.nsherman.info
