SD60P to 25FPS? at DVinfo.net
Old February 21st, 2007, 07:34 AM   #1
SD60P to 25FPS?
Hi there,
Am I barking up the wrong tree or can i do the following... and if so how do i do it?
Capture HDV-SD60P and play it back in a 25P timeline (whether HDV or SD PAL)
J
Natural History Cameraman
Earthmedia Film, Oslo, Norway
James Ewen is offline   Reply With Quote
Old February 21st, 2007, 07:43 AM   #2
If you are on a Mac, you take the .m2t 60P file and open it in MPEG Streamclip. Then you need to transcode it to AIC. FRAME RATE = 59.94. After this point, you open the 60fps clip in Cinema Tools. Then do a Conform (pick your frame rate) and you are done.
Steve Benner is offline   Reply
