LCD goes white when flipped at DVinfo.net
Old February 19th, 2007, 09:38 PM   #1
I take it this is a service issue. Whenever I flip the LCD screen over to tuck it in while turned on, it fades from the center to all white. When I flip it back to face the rear of the camera, it works again, changing back almost instantly. This just started happening today.
Eric Darling is offline   Reply With Quote
Old February 19th, 2007, 10:31 PM   #2
This is a feature of a lot of cameras now. Called a '0lux mode' it uses the LCD as a video light when rotated. I think this probably what you are seeing. If so there should be a setting in the menu to disable it and allow normal use of the LCD.
HTH,
Kyle
Kyle Ringin is offline   Reply With Quote
Old February 19th, 2007, 11:50 PM   #3
Hmm.... I don't recall ever seeing such a feature in the GY-HD100U menus. I'll check again, but this seems unlikely. When the LCD monitor is flipped out, it deactivates the viewfinder on this model (that's normal behavior). Therefore, I can't see what image I'm recording. This is definitely abnormal.
Old February 20th, 2007, 12:28 AM   #4
Kyle, your post made me laugh so hard. That's a joke, right? If it isn't then I'm a dumba$$.
George David is offline   Reply With Quote
Old February 20th, 2007, 12:58 AM   #5
Hook, line and sinker!
Justin Ferar is offline   Reply With Quote
Old February 20th, 2007, 02:07 AM   #6
And rightly so. I'll have to admit I mistook this post for being in the sanyo HD1 forum...
It'd be a bright LCD that could do this on the HD100 past that big lense hood and all! Although I have seen more useless features included with cameras...
Glad to amuse someone - I'll crawl back under my rock now.
