2nd camera to work well with HD100
Hey Gang,
We are looking at a new camera and wondered if anyone had any thoughts or experience, with a smaller, less expensive camera than the HD100 that would work well with our current HD100. We shoot sports for High Schools and my parnter in crime likes the mid sized Canon HDV camera. My concern is that if we end up shooting together, the footage won't match without a good deal of tweaking. Any thoughts, suggestions or experience would be appreciated. Best regards, Tom Chaney |
More info
What my detail challenged friend Tom failed to mention is that it is the Canon
XH A1. We are concerned about the frame size difference between the two camera's as well as any other trouble we would run into during post. We use Final Cut Studio by the way. |
No Love at all!
My brothers!
Are none of you using a different camera as a back up? Tom |
I think you can run the Canon footage through mpeg streamclip to match the resolution of the JVC ...I think. I'm not positive I haven't done it myself.
#5 |
I'm not sure what final cut does to the footage, but Vegas handles it pretty well. The big problems you're going to run into is the color. You'll really have to do a lot of tweaking before hand to get the colors looking similar. We don't like to mismatch cameras. We did a job a couple years ago where we matched a Canon XL-2 and a couple JVC - DV5000's. You definately noticed the differences between the cameras, and with everything we did to correct it, it still looked off. But if you have to, then I would say try it out, but definately do some tests before hand to try and match the camera's native color in the color setting menus.
#6 | |
Do you want to shoot progressive or do you want interlaced and convert it to progressive? I have only seen it at a show, but I think the Sony V1, which is true progressive, might be a good camera. It's the same size as a PD150 (which is smaller than the Z1). When you say "backup," do you mean a camera to use if the other one isn't available? Or do you want something to intercut with the HD100? If you were going to intercut, matching the cameras might be accomplished by setting them up using DSC chart and the appropriate monitors (such as in DVRack). If you were going to use the second camera for special shots, such as closeups on the sidelines, low angle field shots into the lights, etc., getting the cameras to match exactly would be less important. I have done a lot of this with many different DV cameras, but I haven't done so with the JVC cameras and HDV. Based on the responses on this topic in the past, it doesn't seem like many people use a second, smaller camera together with the JVC camera. Most of those who have mixed camera footage in the same project seem to have done so out of necessity, not as part of the plan. Am I wrong here? |
#7 | |
Okay, I just converted a 1080 24f clip to HDV 720/24p in mpeg steamclip and it works great. I would assume that converting a 30f to 30p clip would equal thew same results, as would a 1080 60i to 720 30p.
It has been proven ad nauseum on these boards that 24f=24p. Insinuating otherwise is just misinformation and a disservice to the Canon line of cameras |
#8 |
Double post... please ignore.
#9 |
Thanks guys. Good stuff.
The color was my concern as well. I think that we might be leaning towards another JVC - perhaps used. Tom |
#10 |
Tony,
What canon were you using? If you get a chance I'm sure everyone looking at this post would like to see some side by side footage of the canon and the jvc being intercut. Thanks. Ben |
#11 | |
The results can be excellent from all the cameras. For some people, the H1 has the advantage of producing excellent 1080i, and the extracted progressive video is a bonus. |
#12 | |
No camera is gonna match with another camera perfectly. There will need to be adjustments with both cameras settings and some additional tweaking in post.Seeing footage from the Canon and the JVC tells me that intercutting them shouldn't be that much of a problem. I haven't seen any footage from the Sony (except on these boards) So I'm not sure about the Sony, but I would guess that it would be as good. The problem with the Sony is getting it into the NLE, namely FCP Studio. I know for a fact you can convert Canons HDV clips from 1440x1080 24f 1280x720 24p in a few different formats. Specifically HDV 720/24p the same as the footage from the JVC. Assuming thats the goal. It also works for the other frame rates as well (30p, 60i) |
#13 |
#14 |
2nd camera
speaking of mtaching video, how on earth will I match old footage shot in SD 4:3 and mix it in with my new stuff in HD720-30p?
I have a client who has old video (of family stuff etc) that he wants edited in with new footage. Also, I have a client who has shot some of his mountain bike rides on a small consumer "handicam" (SD 16:9) and wants that included in his finished product. pardon my ignorance but I haven't encountered this before. thanks. |
