Do I really need Dvfilm to Change my 720 24p at DVinfo.net
Old January 24th, 2007, 02:34 PM   #1
Hello all looked for previous post on changing frame rates
Dvfilm shows
Mutate is a simple application (Windows only) which converts 24.000 fps Quicktimes to 23.976 fps Quicktimes. The conversion is done without touching the movie data but simply by changing the flags and rate constants in the .mov file.
I am using Vegas7 for edit!
Can I record at 24p and edit 24p export 24p Or do I really need to use the Mutate??? to make 23.976
Im not understanding the issue?
I almost feel that Dvfilm has the dv/hd market in there grasp!
I just Ditched HDV 60i so I didnt have to use Dvfilm for conversion!
Thx!
Any links or explaination would help!
Steven Lee Houser
http://vimeo.com/testwork
Steven Houser is offline   Reply With Quote
Old January 24th, 2007, 03:12 PM   #2
Hi Steven,
When most people around here say "24P" they actually mean "23.98P," it is just easier to say 24P.
When you record "24P" on a JVC ProHD camera (and most other 24P cameras,) it is actually recording at 23.98fps (23.976 to be exact!)
There is a 0.1% difference in speed, and therefore it is important to make all of your sequences and outputs 23.98 as well.
The only time you would set your sequence to 24fps is when you are working with material transferred from film for eventual neg cut and print back to film. In this case your sequence would have to be 24fps to maintain proper sound sync for when the optical sound elements are eventually married to the picture.
If you do plan to do a film print from video source it is fine to stay in 23.98 through the D.I. and then the lab will take care of maintaining frame sync. The duration of your film will just be 0.1% shorter than the video version.
Tim Dashwood
Old January 24th, 2007, 04:49 PM   #3
Great! Thx Tim!
1 more question I'm not sure about?
When I am finished with editing at 23.98 I want to render a MPEG2 for a stadard DVD Will the setting also be 720x480 at 23.98(23.976) or do I render a 29.97
Last question for Now!
You are so helpfull! and I love your work!
Steven Lee Houser
Old January 24th, 2007, 06:37 PM   #4
Originally Posted by Steven Houser
Great! Thx Tim!
Thanks for the kind words Steven.
You can leave it as 23.98fps for mpeg2 encoding at 720x480. All NTSC DVD players will add the appropriate 2:3 pulldown when connected to a NTSC TV. If you play the DVD on a new "uprezzing" DVD player it will also automatically add pulldown for output to 1080i60 or 720P60. A progressive DVD player and progressive monitor combo will attempt to display a progressive mpeg2 stream without adding any pulldown.
DVD players are very smart, (assuming they are setup properly!)
Tim Dashwood
Tim Dashwood is offline   Reply
