BR-HD50 only wants to record in LP mode at DVinfo.net
Old January 18th, 2007, 12:16 AM   #1
I'm trying to record into my BR-HD50. No matter what I do it switches the mode to LP even though this deck doesn't record in LP mode. I've put in 3 fresh tapes. I try to record, the speed changes to LP then it gives me a LP warning. When I try to play back the tapes I get nothing but a (LP!) warning.
This happens whether the input is a computer or HD100. Anybody have any Ideas? Help.
Evan
Evan Gardner is offline   Reply With Quote
Old January 18th, 2007, 01:36 AM   #2
Go into the menus and execute the factory reset.
I'm not sure how this is even possible, but the best thing to do is to clear everything and see if it still does this.
Tim Dashwood
Old January 18th, 2007, 01:38 AM   #3
Thanks Tim, I have already done this and it has no effect. It does this trying to record DV as well.
Evan
Old January 18th, 2007, 02:35 AM   #4
Evan
Weird. Call tech support. Maybe there is some sort of master reset they can walk you through?
Tim Dashwood
Old January 18th, 2007, 04:26 PM   #5
what tapes are you using?
i recall having more issues with clients using panasonic tapes that had a longer record time.
terry
Terry Nixon is offline   Reply With Quote
Old January 18th, 2007, 06:51 PM   #6
DvCam, and mini dv. It plays everything fine. It only affects record. I even tried prerecording a bit of DVcam at regular speed on another deck, then putting it in the JVC but it just keeps switching to LP.
Old January 22nd, 2007, 03:25 PM   #7
problem solved!!
Well I heard from Doug Mullin at JVC and he told me it was a little known problem from updating the firmware. So he explained to me how to get into the hidden menu and do a reset. I had already reset from the main menu with no effect, but the hidden reset worked. Thanks to everyone for their help.
Evan
Old January 22nd, 2007, 07:53 PM   #8
Double secret menus- just like double secret probation!
Justin Ferar is offline   Reply With Quote
Old February 14th, 2007, 05:28 PM   #9
How did you get into the menu?
Evan
Hi Evan,
I have problems with the firmware update... Can you let me know how you get into this menu and if it will restore the old firmware?
Maxene
Maxene Kuek is offline   Reply With Quote
Old June 9th, 2011, 09:59 AM   #10
Re: BR-HD50 only wants to record in LP mode
Having this problem right now anyone know how to access the hidden menu?
Marc Higa is offline   Reply With Quote
Old June 14th, 2011, 06:13 AM   #11
There is a very good reason why the service menu is hidden - once you get into it, you might just screw up everything.
I suggest you call tech support and they'll walk you through. It is never a good idea to post these button combinations on the internet... using them will cause more harm than good.
Ervin Farkas
www.AtlantaLegalVideo.com
Old June 14th, 2011, 11:07 AM   #12
Thanks I called the service department and we got it fixed!
