jvc hd100 + mini35 relay lens
it's possible to put a relay lens of p+s ( connecting kit for jvc hd 100) and use it with the red rock micro micro35 or other 35mm adapter??
Very interesting idea... I wonder if anyone has tried it?
Tim Dashwood |
the question is, does anyone know what kind of lens p+s is using as relay lens? or at least what focal lenghth. that would be very interesting.
Thomas |
Their relay is not an OEM lens. It's assembled by them. The focal length is unknown but would be a moot point anyways since it's only made to focus within a certain distance.
#5 |
Physically it would not work without some modification or additional connecting pieces between the mini35 relay lens and 35mm adapter - but theoretically it could work.
To Micheal's point the M2, SPGpro, Brevis, etc.. would have be located at some distance away from the HD100 at a focal point unknown. It should also be noted that at this focal point the frame size may not be a full 35mm frame size (36x24) since it's possible some frame size reduction occurs before the mini35 relay lens, and the final reduction for the 1/3" CCD afterwards. In this thread I discuss the prospect of removing the stock lens from a HVX200 and designing my own relay lens system to work with a 35mm adapter. www.dvinfo.net/conf/showthread.php?t=82245 You may find this of some interest. |
