In the absence of 60p, How2getSloMo? - Page 2 at DVinfo.net
Old December 19th, 2006, 07:35 PM   #16
Originally Posted by Jaadgy Akanni
The HD110 doesn't shoot 60p. So my question is: What would be a good and effective way to get professional looking Slow Motion when your only options are 24p and 30p. What's the best software to achieve it?
Hi Jaadgy,
I've created a "How To" that you can probably adapt to your NLE. You should have no problem getting SD50p to work great for your project.
Click here for tutorial
Regards,
S.Noe
Stephen L. Noe is offline   Reply With Quote
Old December 19th, 2006, 09:32 PM   #17
Thanks Stephen. I just watched your tutorial for the 5th time. I love it. So very kind of you to share such valuable learning material. Thanks again.
I will be KING!
Jaadgy Akanni is offline   Reply With Quote
Old December 20th, 2006, 10:20 AM   #18
Jaadgy.
Use the HD-SD50 to shoot at 16:9 progressive with 576 lines, this will give you a 50% real slow mo that wil upscale nicely to 720p. Then use AfterEffects' TimeWarp (FCP frame blending is not good enough) or Shake's Adaptive speed adjustment to slow down the footage even more and it will be pretty convincing. Also remember to increase the shutter speed to capture more detail (this is a very subjective choice and depends on the footage)
Good luck.
Paolo http://www.paolociccone.com
Demo Reel
Paolo Ciccone is offline   Reply
