HD110 stock lens/body-only weight? at DVinfo.net
Old December 15th, 2006, 02:11 AM   #1
Any ideas on how much does the stock lens weight? I`m figuring out how much does the body weight actually.
T
Toenis Liivamaegi is offline   Reply With Quote
Old December 15th, 2006, 12:40 PM   #2
T
For the JVC GY-HD110:
The camera body weighs (without mic or cassette) 3 lbs. 14.5 oz.
The stock lens weighs 2 lbs. 6.2 oz.
The wideangle lens weighs 4 lbs. 2.5 oz.
Old December 15th, 2006, 04:29 PM   #3
In kilograms, the weights are:
The camera body weighs (without mic or cassette) 1.62 kg
The stock lens weighs 1.08 kg
The wideangle lens weighs 1.89 kg
Old December 19th, 2006, 06:46 AM   #4
Of course, if you're going to use the IDX adapter (or A/B or PAG), you'll need to add some (the adapter itself isn't heavy, but the batteries can be of course)
High-Definition Video Consultant - CEO of Delimex NV - http://www.delimex.be
gear of choice : http://www.wespgear.com
Werner Wesp is offline   Reply With Quote
Old December 19th, 2006, 11:27 AM   #5
but i guess with Ab mount (or other mounts as well) the camera will be better balanced on shoulder.
Just my thought :)
Cheers !
Bankim Jain is offline   Reply
