FYI: Super Encoder compared to HD-100 encoder. - Page 4 at DVinfo.net
Old November 21st, 2006, 12:11 AM   #46
Originally Posted by Werner Wesp
I watch F1 all the time, and those super slo-mo shots of the tyres in the chicanes definately are made with a higher shutter then the frame rate. Don't know what the frame rate is, but it could be as high as 400.
Broadcast supermo cameras scan 180 fields per second in standard definition NTSC or 150 fields per second in PAL. HD supermo cameras scan either 120 or 100 frames per second (in 720p, fields in 1080i) depending on the standard. But I've mainly been talking about regular speed cameras slowed down.
By the way. a high shutter speed is just the thing for sports. Otherwise you'd lose the sharpness due to motion.
A fast shutter makes for great still frames but terrible, jerky-looking full-speed footage. That's why you'll rarely see a supermo camera outside of replays.
Still, Newscasting isn't what this camcorder is aimed at...
Oh really? Broadcast stations are a significant market segment for the HD series. The local regional FSN affiliate around here owns an HD100 and is purchasing three HD250s. The camera itself was designed with a form factor that would be familiar to users of high-end ENG camcorders. A JVC representative mentioned in another thread that the 19.7 mbps data rate was chosen specifically so that HDV could be transferred over a microwave link used by newsgathering trucks.
Stephan Ahonen is offline   Reply With Quote
Old November 21st, 2006, 01:40 AM   #47
Sorry, I was talking about the 24/25/30 fps only camcorders (HD100, HD101, HD110, HD111). Obviously the 250 (and possibly the 200) is more geared towards TV-work and newsgathering. 25p only like the HD100 is rather difficult for news...
High-Definition Video Consultant - CEO of Delimex NV - http://www.delimex.be
gear of choice : http://www.wespgear.com
Werner Wesp is offline   Reply With Quote
Old December 30th, 2006, 06:35 PM   #48
Originally Posted by Stephen L. Noe
For kicks here is a Sample Slo Mo which was a snap to do in the NLE. The clip is slowed down to 40% (ie 60fps to 24fps). Easy to do...
Could you be more specific? Did you export as a TGA sequence or just slowed it down on the clip on the timeline?
Peter John Ross is offline   Reply With Quote
Old January 3rd, 2007, 11:40 AM   #49
Blue ch. noise with 85 filter on exteriors in daylight
Stephen, thanks for the test of the 250's new encoder, but how does the blue channel stand up outside with an 85 filter on?
Bill dunn
William Dunn is offline   Reply
