Direct Recording To Hard Drive Options??? at DVinfo.net
Old October 6th, 2006, 08:57 PM   #1
Are there any other options other
than:
Firestore
or
Citidisk
to directly record to a hard drive system?
Rob Stiff is offline   Reply With Quote
Old October 6th, 2006, 09:50 PM   #2
Barry Wan Kenobi
nNovia QuickCapture, but I haven't looked at it in a while and I don't know if it's HDV-compatible or not.
Then there's Sony's DR60 coming out, but I don't know if it supports JVC's HDV or only Sony's.
Old October 6th, 2006, 10:24 PM   #3
DV Rack has a recording feature, but it requires a laptop, so it's not the most portable option. Still, lots of added value with scopes, a 720 true HD monitor built-in (along with SD versions), and nice still store feature.
Eric Darling is offline   Reply With Quote
Old October 6th, 2006, 10:35 PM   #4
I am very happy with my Citidisk. it was alot cheaper than the firestore, and I still got more drive space.
And, during a shoot the drive slid off the shoe mount and fell 6 feet onto concrete, bounced twice and went across the floor.
Still works.
Dont know why it fell off though.
Jim Fields is offline   Reply With Quote
Old October 7th, 2006, 01:27 AM   #5
Thanks Jim, i didnt know about the Citidisk but a question, you still have to convert the M2t files for FCP correct or can you use the Quicktime .mov codec to capture to the drive? (i certainly not try'n to be cynical, looking for a solution to tape and capturing :)
Jamon Lewis is offline   Reply With Quote
Old October 7th, 2006, 06:50 AM   #6
You are tied into the M2T files with HDV.
Witht the citidisk in DV mode you can go straight to mov files.
Old October 7th, 2006, 12:49 PM   #7
Are all HDV direct to disk systems only able to record in .m2t format?
What would the best application be for a studio setting for
direct to disk options?
Anyone out there make a multiple input direct to disk system; rackmount system?
How about firestore? Able to make 720 24p .mov files
directly from the HD100U?
Anyone doing direct to disk and working with the updated FCP / 24P HDV?
Old October 8th, 2006, 09:38 PM   #8
JVC America
Rob, the DR-HD100 (the JVC-specific version of the Firestore FS-4) now offers quicktime mode in HDV - for 25 fps or 30 fps mode. The 24 frame mode is not available yet in quicktime. You can record 24 fps in the .m2t mode and capture that in Final Cut, as you would off of tape. It take real time, but you still get the benefit of dual media and longer record time.
Carl
Carl Hicks
JVC Professional Products Company
Carl Hicks is offline   Reply
