#16 |
Stephen, the video explains it perfectly.
So, at 3.51meg x 24 frames per second x 60 seconds x 120 minutes, a two-hour feature will be 606 gig. I'm going to need a bigger hard drive. Okay, can somebody confirm confirm that it IS best to let the transfer house handle color correction? If I understand David correctly, this is because I've only got a video monitor for viewing, which is a totally different medium from film. Am I right? (I'm on a budget, and I gotta be sure that my sweat and blood won't cut it in this case, so this is one area I can't skimp on) |
#17 | |
See question 17 here: http://dvfilm.com/faq.htm This faq covers some basic questions are is worth reading. I think it's a very good idea to contact the possible transfer houses and get their requirements and info. I'm sure in most cases they have info printed up. |
#18 | |
Tim Dashwood |
#19 | |
William Hohauser - New York City Producer/Edit/Camera/Animation |
#20 |
American Society of Cinematographers
Like I said, you probably should just color-correct for a calibrated monitor but on the conservative side, a little low in contrast but balanced correctly for the color and brightness you want. Then take it to a film-out company and tweak the master so that it looks the way you want in the film-out, based on some tests -- usually a clip reel of shots from the movie.
Choice of print stock also matters; printing the output neg onto Kodak Vision Premier 2393, for example, will give you better blacks and higher saturation than the standard Kodak Vision 2383. Also, the new Fuji XD print stock is very good with rich blacks.
David Mullen, ASC Los Angeles |
#21 |
Good stuff
Great info guys! Thanks for your thoughts on settings Tim and Stephen... Your knowlege helps all of us.
I think David Mullen's advice is the one that I've ended up following - try to shoot the best looking video you can and hopefully the transfer house can take you the rest of the way. Many/most of us are in the same boat - we hope that there will be a need for a film-out as that means it's been picked up for theatrical release... However, we are realistic enough to know that, given most of our budgets, video and internet are the likely destination for our work. David's suggestion to shoot for film, then plan for a back-to-video transfer is beyond most of our budgets - but it is an interesting idea - particularly for people doing shorts. Thanks for the tip about a camera's 'log book.' Any more specific information about log books would be great (ie - does the JVC100 have this capacity? I'm guessing not...). Thanks again to all those who've shared - john evilgeniusentertainment.com |
#22 |
Thanks guys for the info. I now feel armed, loaded, and ready to advance upon the film transfer house tomorrow.
12 months ago I hardly dreamed doing a film-out was possible, but put an HD100 into a guy's hands, and... Great camera! Great bunch here at DVinfo! |
#23 | ||||||||||
Filmouts from the HD100
Hi all,
Andy form DuArt here. I’m on the road at the moment – sorry I did not see this thread sooner. For those interested in this subject, the cover story of this month’s DV Magazine is about shooting the HD100 out to film. The story features an HD100 filmout that DuArt did for John Jackman and includes John’s analysis, a reaction to the print by a group of DPs, as well as our shooting and submission guidelines for HD100 footage. Unfortunately, the story is not posted online, so I can’t give you a link to go to. Try to get a hold of a copy if you can. In short, our guidelines pretty much state the obvious and echo what Tim said earlier in this thread (be very mindful of exposure and focus, turn detail way down, do not use the filmout setting, don’t crush blacks, etc.). What I don’t have just yet is a recommended recipe that will maximize image information for post-production color correction and/or filmout. We are working on that at this moment, but with many cameras and projects to juggle, it is taking some time, I’m sorry to say. Please stay tuned. Some specific comments: Quote:
So while we're waiting for a better recepe to come along, try the settings offered on this forum, or use the camera default - just keep detail down, mind your exposure and don't compress your blacks. If you are fortunate enough to need a filmout the post facility will indeed deal with it!
Andy Young Director/DP www.ArchipelagoFilms.com VP, Special Projects www.DuArt.com |
#24 |
Detail Question...
So when everyone says turn the detail down is that because it will have that 'sharp video' look or because of something else, because for my project the sharper the better, or does detail do something else?
#25 | |
#26 |
Here is something I've been wanting to mention for quite a while. When capturing out of the component out's of the camera or deck the edge enhancement is very apparent, however, when capturing through firewire (same footage) from tape, the edge enhancement disappears from the exact same footage. I find this unusual that the edge enhancement is so apparent out the analog out's but conversely the edge enhancement is non apparent on the data coming through the 1394. Must be the encoding, right? Not so! Try playing a tape out analog to HDTV and then try playing the same footage off your NLE timeline to the same HDTV. Where did the edge enhancement go?
Advanced Avid Liquid Training found Here |
#27 | |
Your saying that footage that was recorded to tape shows enhancement when played out analogue, but captured via firewire and then played out it doesn't? That's really bizarre. Unfortunately, I've got tons of footage, all captured over firewire, that exhibits plenty of ugly default enhancement no matter how it's played out.
#28 | |
Both camera and NLE are connected to the same HDTV. The camera is connected via component and the NLE is connected via DVI. On the HDTV, I just switch between sources and its absolutely obvious the analog out is over enhanced while the timeline footage is not enhanced. This is true when I play footage through 1394 and then pass through the camera to it's analog out's and then out to HDTV. I really think it's a bug with the analog outs to show that much enhancement and yet the captured footage show not nearly the enhancement.
#29 | |
Monitoring "film-out" settings on JVC HD-100
#30 | |
Now you have my wheels turning again about capturing using the filmout setting via YPbPr directly to uncompressed 10bit 2vuy. Since I'm not sure the detail in the blacks can be brought up (even by the post house's experienced staff) I'm not really game to shoot in filmout gamma and spend the $$$$$ for a failed trasfer merely because of the (my) misunderstanding about the transfer technology. So, I can see why the DP you referred to lost confidence and went into C.Y.A. mode. Think about it. Nobody wants to look at daily footage that's drab. I'm sure the producer would have a heart attack looking at dull footage. S.Noe
