Need info on Dionic 90 battery
Since many here got the Anton Bauer promotional kit with their HD100 camera, I have a question.
Can one or more of you tell me what the battery lcd reads for remaining time after a full charge? I could have sworn that I saw nearly 3 hr being displayed on full charge before. Now, the battery shows only 1 1/4 hours on a full charge. It's too new to be doing this. I want to contact AB asap about this. TIA, -gb- |
Greg:
Yes, it should show 3 plus a complete pie when fully charged. I haven't had this problem with mine yet, but I have heard something about the Dionics (and Hytrons) needing their meters reset from time to time. Contact the Anton/Bauer Customer Support Dept at (800)422-3473 or support@antonbauer.com, they'll walk you through it. Have the serial number of your batteries and charger ready when you talk to them.
Charles Papert www.charlespapert.com |
#3 | |
-gb- |
#4 | |
I talked to AB this morning. The LCD reset is simple, a paperclip or other object should be inserted in the small hole above the lcd until it flashes briefly. Unfortunately, that didn't fix the problem. Was going to send the battery in to AB but noticed in the manual that if the side bars next to the digital fuel gauge are slowly flashing (mine were), it indicates the battery/charger need to re-calibrate the remaining capacity. this happens if the battery hasn't been fully discharged in awhile. To recalibrate with the Titan series chargers, the battery needs to be discharged, then placed back on the charger. I did the discharge by turning on the camera and letting it sit idle. The battery is re-charging now and the bars have stopped flashing. Hopefully, this will take care of it. Will update this thread as soon as I know. -gb- -gb- |
#5 | |
Hooray, I am now back to showing 3 plus a full pie, meaning I should get 4 hours on a 20 watt load. The 20 watts is what the battery uses as a reference when it's not connected to anything in order to give a time estimate readout on the LCD. -gb- |
