Mpegstreamclip?? at DVinfo.net
Old September 16th, 2006, 07:38 PM   #1
Mpegstreamclip??
I have been reading that MPEGSTREAMCLIP can be used to capture 720p 24p footage to be used in FCP. I have MPEGSTREAMCLIP but whats the process for captureing? FCP doesn't rcognize the camera so how do I get the footage from the camera into MPEGSTREAMCLIP?
Maybe I am missing the obvious, but I can't figure this out.
Please help.
BC
Britt Cyrus is offline   Reply With Quote
Old September 16th, 2006, 09:36 PM   #2
Hi Britt.
You can use DVHSCap to capture. Use the search function and you will find numerous threads concerning the use of DVHSCap and MPEG Streamclip in both this forum and the "Final Cut for HD/HDV" forum.
David Knaggs is offline   Reply With Quote
Old September 16th, 2006, 11:57 PM   #3
The stream coming from the camera is an MPEG2 Transport stream (.m2t), MPEG Streamclip can be used to *convert* .m2t files to standard QT .mov files. The capture process has to be done by another program. You can use HDVxDV (payment) or DVHSCap. The latter is part of the FireWire SDK from Apple (http://developer.apple.com/sdk/) Just install the SDK and forget about the other apps. Drag the DVHSCap app to your Dock or desktop and you can start capturing with it.
Paolo http://www.paolociccone.com
Demo Reel
Paolo Ciccone is offline   Reply With Quote
Old September 17th, 2006, 11:27 AM   #4
Paolo,
thanks a million. I just captured 720p 24p and imported to FCP.
takes 2 extra steps but I can do it!!
THANKS!
Old November 9th, 2006, 02:44 PM   #5
1st time with MPEG Streamclip
so, when using MPEG Streamclip with HDV 720p30 footage, when exporting to QT, i'm assuming under Compression, I'd select "Apple HDV 720p30", with quaility set to "100%".
Editing in FCP 5.
i have to capture a lot of footage this way, so want to make sure i have it right before getting hours into this. any other settings i should make? other recommendations? I unchecked the "interlaced Scaling" and "reinterlace chroma" check boxes.
Eric Kome is offline   Reply With Quote
Old November 9th, 2006, 04:17 PM   #6
Not quite. MPeg Streamclip re-encodes during the "export" process, so selecting the HDV 720P30 codec will re-encode your existing HDV into HDV AGAIN.
I recommend using Apple Intermediate Codec. It is an all "I-frame" codec that is indistinguishable from the original, and the data rate is only about double of HDV.
However, since you shot 720P30, you really don't need to go through all of this extra work. FCP5 fully supports 720P30 HDV natively. Just set your easy setup to HDV 720p30 and you are set. You can log and capture with TC just like DV.
Tim Dashwood
Old November 9th, 2006, 07:24 PM   #7
One item to make sure is that MPEGStreamclip is set to 23.98 fps when converting HDV 24p. You'll have to manually type it in otherwise it defaults to 60p and creates a huge file in the process.
William Hohauser is offline   Reply
