#16 | |
Hockey? That's a tough one, especially if you are at rink side. The distances are great. I would use the servo in that situation. From years of working with cheap and middle of the road lenses I've leaned to do two things; get reasonably good at judging distance and if possible prefocus the setting you are in. If I'm shooting a kickboxing match and I'm a corner camera, I'll check the focus settings before the shoot. That way I can use my left eye to quickly spot check the focus ring and shift it to the right distance. Years ago we used to have lenses that had a place to screw in a pull rod on the focus ring. That way you could orient the focus by the direction the rod was pointing. The stock JVC lens doesn't have a place for that and probably couldn't successfully have one. Now the focal sensitivity of HD is making my old techniques need a rethink. That and the low sharpness of the JVC viewfinder which makes focus a guessing game during chaotic filming. The focus assist function helps but it can be a hinderance if you need to ride the exposure at the same time. I was watching the US Open yesterday and I was surprised at the soft focus with some of the close-up shots of the awarding ceremony. And those are some of the best HD camera available.
William Hohauser - New York City Producer/Edit/Camera/Animation |
#17 | |
I guess it comes down to the method you're used to and what works for you. |
#18 |
Interesting debate...suffice it to say I'll be using the motor zoom from now on (was worried the servo noise would be picked up on tape - not so much of a problem with an add on mic).
Still, the zoom isn't the fastest and for certain types of work (you all know that super quick zoom shot for corporates) I'll use the manual zoom dial. |
#19 |
The manual zoom is nice when its mounted on a tripod becuase it is on the same side as the vf/lcd. I hate having to reach over to fiddle with the zoom lever. Even in run in gun instances, I love the manual zoom.
#20 | |
