OK to MIx JVC ProHD and JVC DV Tapes...? at DVinfo.net
Old August 12th, 2006, 01:42 AM   #1
I just received the new camera. (I opted for the HD110 instead of the battery promotion.) I have bought and plan to use the JVC ProHD tapes for all HDV shooting -- as advised here and advised by a local JVC dealer who also rents the JVC cameras.
However, when shooting SD DV is there a problem switching to the JVC DV tapes?
Or is it advised to use only the ProHD tapes for everything? I also use DV Rack for long time shooting, which would be the only time I use SD DV, so the JVC DV tape would acutally just be a backup, and in these situations I use more than one camera, so I'm not concerned about an occasional glitch in the tape.
However, I don't want to mess up/dirty up the heads in the JVC camera -- but I don't know if this is an issue if sticking with the JVC tapes -- ProHD and DV.
(I also have the JVC VTR, but it will only be used for tapes from the JVC camera. Everything else I have is Sony, and with these cameras I use only Sony tapes, and I also have a VTR for the sony tapes.)
Old August 12th, 2006, 02:12 AM   #2
Risk vs benefit
Well, here's the thing - probably it'd be okay. It's not like you're putting a hunk of peanut butter into it...
But, this camera, while being almost supernaturally tough in some ways, does seem finicky in others. When it comes to to tapes, it seems (perhaps inescapably so) to be band tape senitive. Also, I doubt too many here have done exactly what you're trying.
Me? I think the risk is low. But, this is a new technology doing what even 5 years ago would've seemed impossible, or at least prohibitive money wise. Fact is, even if it did work w/someone else's camera, it might not work out 4 you. It's what you'd risk. Let us know... And good luck.
john
evilgeniusentertainment.com
John Vincent is offline   Reply With Quote
Old August 12th, 2006, 05:01 AM   #3
I wouldn't do it!
Why would you risk missing something just to save a few bucks?
There are plenty of forums here that specifically state problems related to this issue.
Pretty much it appears that you should stick with one type of tape and not switch.
Just my opinion.
Tom
Tom Chaney is offline   Reply With Quote
Old August 12th, 2006, 05:54 AM   #4
I use the cheap $3 Sony Premium tapes for standard & HDV recording.
They seam to work out fine for both formats. I'm not really shooting anything critical enough that I would spend $10 per tape. The dropouts are minimal. I'm only charging $40-$50/hr right now. I'm not interested in spending 25% of my hourly rate for tape stock. Screw that!
When I get more business, I can raise my rates and perhaps incorporate the better tapes into the deal.
Scott Jaco is offline   Reply With Quote
Old August 12th, 2006, 06:16 AM   #5
Using the cheaper tapes shouldn't be a big problem as long as you stick to the same type. Different brands of tapes use different types of lubrication, and mixing those can cause problems. If / When you decide you must switch to a different tape, run a cleaning tape before putting the new one in. Don't just switch back and forth though, pick a tape and keep with it until you are forced to change.
I need to re-read about the JVC tapes, but a book I got about this stuff mentioned that some brands had no difference in the actual tape, just that the professional ones had a more sturdy case.
I just bought an HD-100 (probbably the last one), and where I am for now I cannot get the professional tapes. So I will use the regular JVC tapes till I get back to to the US, then run a cleaning tape before switching. If I switch at all, if I do not see dropouts, I will not switch.
Justin Deming is offline   Reply With Quote
Old August 12th, 2006, 08:08 AM   #6
I'm with scott
I use the 3$ sony tapes too, for 120 drum Hr till now, haven't sean any drops or quality lost
Shai Camerini is offline   Reply With Quote
Old August 13th, 2006, 12:08 AM   #7
I use the sony cheap tapes too!
Always stick to the same brand.
Jonathan Nelson is offline   Reply With Quote
Old August 13th, 2006, 02:41 AM   #8
even if you did switch brands (which some folks do all the freakin' time) wouldn't a pass through a head cleaner reset everything anyway?
Old August 13th, 2006, 08:39 AM   #9
It supposed to do that, but remember that the cleaning tape can do a lot of damage to the video head, so don't use it too often.
Old August 14th, 2006, 07:23 PM   #10
Don't get complacent about the tapes. I was happily shooting on Fuji DV tapes until I had a serious amount of dropouts on one tape during an important shoot. That was a real problem. I decided that I should try "HDV" tape instead. I was shooting with JVC's "HDV" tape and guess what? Suddenly one tape had the worst set of dropouts I've experienced yet. Unfortunately these are recorded dropouts not playback problems. Fortunately it wasn't a client shoot, just some vacation footage. The next tape was fine.
I have a Focus Enhancements hard disk recorder on order. I'm never going to be in that position again until tape production is improved.
Old August 14th, 2006, 09:21 PM   #11
I use Sony professional HDV tape and get a bad tape once in a great while but I review my footage every time I shoot to make sure there is no problems.
Gary Williams is offline   Reply With Quote
Old August 15th, 2006, 06:18 AM   #12
When cleaning the heads with the head cleaning cassette, does it also clean the record head? If not, how should I clean the record head?
Thanks.
Carl Martin is offline   Reply With Quote
Old August 15th, 2006, 04:22 PM   #13
HDV Cinema
Thanks.
The "heads" are all one unit.
The rumors of head cleaning tapes causing damage seem IMHO to be either from someone playing them past a count of 10 -- or there having already been some damage -- which is why they were trying to clean the heads -- and the cleaning tape gets the blame.
I also have mixed tapes from day 1 of HDV. Some JVC DV, some Sony DV, some Panasonic DV, plus JVC ProHD and Sony HDV and Sony DVCAM. It seems all work fine. BUT, the probability of encountering a bad tape as well as the probability of DO is LIKELY lower with the PRO tapes or HDV tapes.
So I see the extra cost as insurance.
As far as mixing tapes -- when I get equipment for review they usually include some of their own tapes. Overtime, without even thinking about it, I've used every brand of tape in every brand of equipment. Wet or dry -- I've never experiened any difference. So if I was on location I wouldn't panic if I had to run another brand.
But as insurance I would use the head cleaning tape.
And as insurance I would try to stay with one brand.
Old August 15th, 2006, 04:36 PM   #14
Ok, thanks.
Old August 15th, 2006, 04:40 PM   #15
What has confused me is why make a machine that plays DVCAM (not records) if one should not put Sony tapes in that machine if you also put JVC tapes in that machine.
Obviously, many, many DVCAM shot tapes are going to be on Sony tape. I have the JVC vcr, but the JVC rep advised me not to put Sony tapes in it -- so why does it play DVCAM?
It seems that Panasonic makes JVC and Canon tapes, so I suppose these three should theoretically be compatible in regards to tape lubricant.
The original problem a few years ago was the lubicrants on the Panasonic vs. the Sony tapes. When mixed, these became tacky. However, I have been told this problem no longer exists. I don't know if this is true. A long time ago I mixed TDK and Sony mini DV tapes regularly, and never had a problem.
I bought the JVC ProHD tapes, but before I put one in the camera, I wonder if I should just use Sony tapes in the JVC camera, since everything else I have is Sony.
I originally bought the BR-HD50U thinking I could get rid of my DSR-11 -- thinking that if it played DVCAM tapes, it would be no problem putting Sony tapes in it. At the moment I have decided to keep the DSR-11 until I make a final decision on what tape to use in the HD110 camera.
As a side note -- in the vtr, is there a problem mixing mini cassettes and full size cassettes in the same machine?
Jack Walker is offline   Reply
