Anyone using wide angle lens adaptors?
Just wondering how good the WCV-82SC is. Is it a full zoom-through WA adaptor? Any distortion? Can you fit a lens hood over it? I"m looking for a WA adaptor to keep on my second HD100 permanantly, so I need something that allows the full zoom range with distortion.
#2 | |
A wideangle "converter" is 100% zoom through. In this thread I link to below, I outlined the adapters from Century with links: http://www.dvinfo.net/conf/showthrea...ght=wide+angle These are the ones recommended by Century reps at Cinegear in L.A. They are the standard adapters Century has sold for different cameras (using different adapter rings to go from the adapter to the camera) for several years. They are apparently top sellers. Both Century and JVC sell a .8x converter. These are zoom through. The only difference between them -- according to the Century reps -- is that the Century converter has better optics at the very outside corners/edges. He said the difference is probably not noticeable by most people. When I called Century last week the person on the phone also mentioned a screw-in adapter. I think it was .6x (not sure) and if it is the one I have read about, it may not be as acceptable as the other choices -- though don't have details. CAVISION also has an adapter that I believe is partially zoom through. But I don't have any information on this one, the quality of it, etc. If you are going to leave it on the camera -- the .8x converter might be the best. However, if you are going to need to go more wide-angle, the Century .5x / .7x combo adapter might be more useful -- especially for a second camera -- depending on what kind of shots you are looking for. But with this adapter set there is no zoom. I have yet to try these adapters myself, since my HD110 camera is in route. However, I have used the .65x converter from Century for years, and it has proven to be excellent. A minor consideration might be that the converters are generally a bit heavier than adapters... but with the HD100 I doubt this would be important. |
#3 | ||
#4 | |
The Century webiste is confusing. However, they are available by phone and will give you precise info -- at least from my experience. Here's a link to the phone numbers. I have always called West Coast office, since they are down the street from me. http://www.dvinfo.net/conf/showthrea...ght=wide+angle If you talk to them, and want the details verified (part numbers, is it for sure what you want, etc.) let me know and I will go in and talk to them face to face. I am going to buy something for my new camera, so I am happy to look into it more. |
#5 |
I got the WCV-82SC WA adaptor and KA-551U Tripod adapter with the offer in Canada.The adaptor has proved to be quite useful in close quarters, and it is full zoom through. It screws on the end of the standard lens, but it is a fraction larger in diameter then the end of the standard lens, so once on you can't take the lens hood off without taking off the adaptor. As for distortion, for the price, well I'm happy with the results.
Here is a slow motion clip using the WCV-82SC Wide Angle adaptor, you be the judge. The clip is a large windows file, so you will need a fast computer to view it on. http://www.portstanleynews.com/TV/BMShow.wmv |
#6 | |
Converter = 100% Through Adapter = None or Partial Zoom Through |
#7 |
what does it mean zoom through?
#8 |
The JVC WCV-82SC is a zoom through converter which means that the converter does not impede the zoom capabilities of the lens. The lens will operate normally as if the converter was not attached.
#9 |
Beware of using any adapter that isn't aspherical, as spherical elements without fail increase the zoom's barrel distortion. That's ok if you only shoot landscapes in the great outdoors, but you'll not be wanting to track room to room and have the door frame bow outwards as you pass through it.
tom. |
#10 | |
However, because of the increase of depth of field and the wider view causing camera movement to be lessened, the adapters work very well in close quarter handheld shooting. Also, adapters (without zoom through capabilities) are necessary for the wider x. The good quality converters are .8x, while the good quality adapters are .7x and .5x (with the Century kit the .7x is used together with the .5x to get the .5x setting). I will also mention that the Century adapters are used on many cameras and need an adapter ring that goes between the wideangle adapter and the particular camera being used. |
#11 |
I've not come across a camcorder fitted with a wide-angle adapter that cannot be zoomed, Jack. I've owned and used many camcorders and have 7 different w/angle adapters in my kit, and all have allowed some sort of zooming.
My most powerful 0.5x converts my Z1's 12x zoom to a 6.2x zoom - still very useful in the field. Not sure what you mean when you say, "with the Century kit the .7x is used together with the .5x to get the .5x setting).'' You can indeed use two single elements together, but the negative power will be greater than the most powerful. And surely you can just order your Century lens with the attachment thread that matches your zoom's filter thread? What's this about step rings being needed between the two? tom. |
#12 | |
.7X Wide Angle Adapter sold alone ($449.95): Part Number: WA-7X93 http://www.bhphotovideo.com/bnh/cont...ughType=search .7X .5X Wide Angle Adapter Set ($949.95) Part Number WA-7X5X http://www.bhphotovideo.com/bnh/cont...ughType=search Here is the adapter to put these on the HD100: http://www.bhphotovideo.com/bnh/cont...ughType=search These are the "industry standard" adapters. They are meant to be put on the the camera lens at it's widest setting. Some camera lenses may allow partial zooming. However, they are not meant for zooming. On the other hand, a _converter_ converts a zoom lens to a wider zoom lens. The .8x from both JVC and Century for the HD100 is a converter, not an adapter. An adapter allows one type of thing to be used in a limited way as if it were another thing. A converter completely transforms one kind of thing into another kind of thing... in this case into a zoom lens of a different range. |
#13 | |
#14 |
Wide-angle adapter - century optics
I want to get one of the Century Optics adapters (.7x). I have a few question to those who have the adapter and are using it on the HD100 stock lens. On the B&H site it says it needs a step-up ring that "slips over a 85mm diameter lens and allows connection to the WA-7X93" - the stock lens is an 82 mm diameter lens, no?
1.) So how does this work with the 85 mm "slip on." 2.) From the photo I can't tell but "slip -on" means not a threaded step-up ring? 3.) Will I be able to still use the rubber hood that came with the stock lens when using the wide angle adapter? Your answers would be much appreciated. Thank You.
........................... Miklos Philips Producer-Director Point Zero Pictures http://www.pointzeropictures.com Last edited by Miklos Philips; June 28th, 2007 at 05:29 PM. |
#15 |
0WA-7X93-00 wide-angle adapter
I just bought one of these suckers from B&H, but neglected to look into a lens hood, once the adapter is screwed on to the Fuji 16x lens. The Fuji hood is no longer usable once the adapter is on. Does anyone actually own one of these things? What did you use for a lens hood? No info on B&H or Schneider Optics site on this... Sheeesh!
........................... Miklos Philips Producer-Director Point Zero Pictures http://www.pointzeropictures.com |
