How are you aligning your cameras? at DVinfo.net
Old August 4th, 2006, 03:06 AM   #1
What chart are you using for aligning your HD100’s? The DSC Camalign seems to be the best but cost an arm, a leg and an eye.
Michael Maier is offline   Reply With Quote
Old August 4th, 2006, 05:51 AM   #2
Capt. Quirk
I'm using a Siemen's start chart I found online and printed out. It's not just that I'm cheap, but I can't see spending that much for a laminated chart. Besides, to buy it at that price would just encourage them to charge ridiculous prices on everything. Special videographers chewing gum- only $200!
www.SmokeWagonLeather.us
K. Forman is offline   Reply With Quote
Old August 4th, 2006, 08:25 AM   #3
I think there is a chart in your users guide/book thing???
Jerry Porter is offline   Reply With Quote
Old August 4th, 2006, 08:38 AM   #4
Capt. Quirk
Yes, I think it is in the Lens manual.
Old August 4th, 2006, 09:57 AM   #5
yep, its in that green booklet that comes with the lense.
works perfectly well for me.
Mark Silva is offline   Reply With Quote
Old August 4th, 2006, 10:03 AM   #6
Are you using a focus chart to align your cameras? I'm not talking about back focus adjustment.
Old August 4th, 2006, 10:09 AM   #7
Capt. Quirk
Then we obviously misunderstood what you were asking. What is it you are trying to do?
Old August 4th, 2006, 10:22 AM   #8
Capt. Quirk
Ok... I think I understand what you are trying to do. I checked it out at CineAble http://www.abelcine.com/store/produc...7&cat=0&page=1
Being new to this type of set up, that is unknown territory for me. However, Paolo and a few others have mentioned these charts with great results. I'm sure they have been used heavily while working on scene recipes.
Old August 4th, 2006, 10:25 AM   #9
I know what he's talking about now. To answer the question - I'm not, I haven't had a need to match to another camera and I'm using Palo's True Color 3 settings and have been very pleased!
Old August 4th, 2006, 10:27 AM   #10
Capt. Quirk
Of course, this does bring up the answer to matching multiple cameras on a shoot. It would make color correction easier.
But then, wouldn't you also need to run a waveform and vectorscope to do any good?
Old August 4th, 2006, 12:10 PM   #11
My experience with many, many multicamera DV and HDV shoots is that if the menu settings are identical, then the pictures will be. I'm sure there's some cameras that are off, but I've never come across any.
The few times I've had black levels off, later investigation showed that it was operator error (somebody not being thorough enough).
My guess is that the true issues with camera setup in a modern camera are already taken care of at the factory in order for the camera's DSP to work correctly.
My Work: nateweaver.net
Old August 4th, 2006, 12:38 PM   #12
Do the settings that are recorded on the SD card (scene files?) have all the settings to reset the camera after they have been manipulated manually?
That is, can all settings be reset by putting an SD card into the camera, or are there certain setting that can only be reset manually.
Similarly, is there a reset button or similar that will completely reset all setting on the camera to the factory default?
Old August 9th, 2006, 12:34 PM   #13
You don’t align a camera only to match another camera. You align it to get the best out of it. You shouldn’t trust the factory alignment either. You should do your own and according to your shooting needs. A Siemens star is not the right tool. A great tool for that i is a DSC Labs Camalign chart (short of course of their prohibitively expensive Chroma DuMonde chart), but they are really expensive. But you need at least an accurate color chart, gray scale and resolution chart and a waveform monitor.
