Thread Tools
Search this Thread
Mac mini for component capture
Hi
I have posted this in the tapeless area as well. Hope that's ok! I was wondering if it was possible to fit a component capture card inside a Mac Mini and use an external hard drive. (with a lossless codec perhaps) I think the offical answer from Apple would be no. But is it possible? I think the Mac mini can work from battery so it could be portable. Thanks Trevor |
Trevor
The mac mini is packed very tight with components, and there are no free PCI slots for adding cards like a Kona etc. You can only add ram. The only mac with free PCI slots is the PowerMac G5 There may be external conponent capture boxes out there. Andrew |
Hi Drew
Thanks for this. In terms of space, would it work if I dumped the dvd drive etc? Don't know how to get over the 'no pci slot' issue though. Do you know of any ecternal boxes that might hold such a component capture card? Thanks Trevor |
#4 | |
Unfortunately a PCI slot can not be added to the logic board. Andrew |
#5 |
Check out what these guys did with mac mini's:
http://www.21stcentury3d.com/press/pr-060117-3dvx3.html I have actually researched this a while back and came to the conclusion that it would be a pain in the ass to use one of these mac minis. Granted, I am not the brightest crayon in the box. I would love it if someone created a diy on how to use one of the mac minis as a dte. Its a great idea though, because the mac mini is so cheap. Please tell us if you ever do figure it out. |
#6 |
Hey guys (this is my first post by the way so bare with me!) i wanted to piggy back on the gentleman's question well kinda... my question is about how to actually use a capture card or really a converter.
more specifically with a a/d coverter would u (obviously i guess) run it thru and capture tto the computer live? What capture preset options would u use in FCP,coming from component out 10 bit raw into the converter, into FCP? the last question in this line would be (this may be an obvious one too :( i would have to record to tape also so there would be a time code correct? Thanks |
