#16 |
I've always looked at Canon vs. Fujinon as pretty much a Ford / Chevy argument. They're both great. They both have an amazing product line, a legacy for high quality and solid reputations. You'll find plenty of dedicated fans in both camps. I think the pricing is your general guide... it's not so much one manufacturer being "better" than the other, as it is that the more expensive lenses are "better" regardless of who makes them.
#17 |
Chris is right. The HD100 uses ENG style lenses which is a whole different ballpark than the dedicated lenses for the H1. And even within ENG lenses there are "professional" lenses and then there are "broadcast" lenses. It's not unusual for a broadcast lens to cost $10K or even $20k.
Fujinon will be expanding their 1/3" lenses for the HD100 later this year. Among them is a premium HD lens with all the bells and whistles of a digital servo (DigiPower). It will probably cost around $10K. Canon will also introduce it's first 1/3" lens for the HD100 later this year and I think it's also pretty expensive ($5K and up). |
#18 |
Thanks Tim, thats good to know there will be something less than the 13k msrp lens out now. Hoping street prices will bring them down even further.
Boycott Guinness, bring back the pint!!! |
#19 | |
JVC America
Gy-hd250
The GY-HD250U is estimated to ship around October or November, at an estimated list price of $8995.00 for the head. It will use the same accessories and lenses that the GY-HD100U / GY-HD110U use. Standard bayonet lens mount that can accomodate your choice of now 5 different 1/3" lenses, or 1/2" or 2/3" lenses with a small adaptor, or many different prime and still camera lenses. I think the GY-HD250U will have the kind of features you are seeking. It will have all of the features of the GY-HD110U, plus these key new features: HD-SDI out / SDI out Component out and composite out at the same time Dedicated audio outs Time Code in / Time code out CCU control port Genlock in Five HD record modes: 720p/24; 720p/25; 720p/30; 720p/50; 720p/60 Regards, Carl
Carl Hicks JVC Professional Products Company |
#20 |
Thanks Carl,
Is there any way to take advantage of the SDI out in the field and record an uncompressed signal? Will the cameras SDI out work on HDV playback from the camera?
www.digitalfx.tv |
#21 |
JVC America
HDSDI recording
Greg,
There are several HD-SDI recorders that you could connect the camera to. Tape based formats, like HDCam, D5-HD, or DVCPro HD. Or disc-based products, like Doremi Labs, Grass Valley, Leitch, or Cineform. Although none of these product are exactly "portable", you could use them with the GY-HD250U to record HD-SDI. Check out the Waifain HR-1. It looks interesting: http://www.cineform.com/products/WafianHR1.htm And yes, upon tape playback, the GY-HD250 will output the signal, uncompressed, on the SDI / HDSDI connector. Regards, Carl
#22 |
If only it wasn't it $15k!!!
Since that unit will also record from the the HD100/110/200, how would the quality compare with HD250, all recorded directly to Cineform? Do you have samples??? Question: Does this also bypass the HD100 audio compression? |
#23 | |||
JVC America
#24 | |
Carl- The SDI / HDSDI connector plays from tape uncompressed?? How is this possible, the tape records a HDV compressed signal?
www.digitalfx.tv |
#25 | |
Sponsor: TapeWorks Texas
As Carl mentioned, estimated List is going to be somewhere around $8995 for camerahead only (possibly viewfinder included). A working ENG package with lens will be close to $12K and studio packages will be around $20 - 25K depending on the lens. Scott Cantrell TapeWorks Texas Inc - HDVinfo Sponser www.tapeworkstexas.com scott@tapeworkstexas.com 866-827-3489 |
#26 | |
JVC America
If you have the camera set up live, the signal on the SDI / HDSDI is uncompressed.
#27 | |
www.digitalfx.tv |
#28 | |
JVC America
No, I did not ever say that it would be identical. Certainly, with any video tape recording, there is some loss, sometimes a very little, sometimes more than a little. You will have to be the judge for it your self when the camera ships. You asked if the signal out of the HD-SDI connector upon tape playback is uncompressed, and the answer is yes. It's an uncompressed signal, sourced from the decompression of a compressed signal. In that regard, it's just the same function as a HDCam or Varicam camcorder or VTR. There is no HD video tape format that I know of that does not have some sort of compression.
#29 |
Thanks Carl,
I always assumed the HDSDI out would only play the compressed HDV signal, and the only way to get uncompressed out of the camera was "live". Thanks for the clairification.
www.digitalfx.tv |
