Nikon or Canon Lenses for the HD100 at DVinfo.net
Old July 25th, 2006, 10:04 AM   #1
Hi Guys,
I looking to buy a JVC-GY-HD100. I read somewhere that you can use your old canon or nikon lenses with it. Is anybody doing that? and if so, what do I need and how much does it cost?
Also, I i think I remember the JVC guy telling me at broadcast live conference (in London) that there's a model coming out that you can undercrank or over-crank, but the dealor hadn't heard of it. Anybody know anything about that?
Thanks in advance,
Vasi.
Vasi Hasan is offline   Reply With Quote
Old July 25th, 2006, 10:10 AM   #2
I think your talking about the Red Rock M2 adaptor or the Letus adaptor. Do a serach on them you'll find tons of info. Also see thier websites for more info as well.
Jerry Porter is offline   Reply With Quote
Old July 25th, 2006, 10:46 AM   #3
Jerry,
isn't the redrock an attachment on the lens itself? for cameras with non-interchangeable lenses?
I guess I'm looking for the right bayonet - if there is one for the old nikon and canon lenses. I was wondering if anybody uses those lenses with the HD100.
Vasi.
Old July 25th, 2006, 11:09 AM   #4
Red Rock also has a mount for the HD100, So does letus. As far as just putting a SLR lens on the front of the camera I have seen it done here on DVi, but it took some MAJOR doctoring of the lens and it was a canon 50mm I think. The post was in the past couple of weeks on this forum. So look around and you'll find it.
Old July 25th, 2006, 11:22 AM   #5
[QUOTE=Jerry Porter]Red Rock also has a mount for the HD100, So does letus. As far as just putting a SLR lens on the front of the camera I have seen it done here on DVi, but it took some MAJOR doctoring of the lens and it was a canon 50mm I think. QUOTE]
Is this accurate? I thought there WAS a simple adaptor for adapting a nikon lens. Seemed like guys were using long lenses for nature photography.
Old July 25th, 2006, 11:31 AM   #6
[QUOTE=Brian Luce]
If that's the case I'd really like to see it. I could be totally wrong. I HOPE I AM! I have thousands of dollars of Nikon lenses that I would love to use on the front of my HD100
Old July 25th, 2006, 12:23 PM   #7
In fact, there are two of them. Zoerk and Les Bosher have both made F-mount adapters.
Andrew Young used the Zoerk adapter for the amazing long-lens footage he shot for the Madagascar doc. (Look at the shot of the frog on the linked page.)
Here's an article if you are interested: http://www.jvcpro.co.uk/getResource2...ar.pdf?id=6228
Yusuf Thakur has also been using it with great success.
Both are members here at dvinfo.net. Try searching for posts by either of them with the keyword "Nikon"
Tim Dashwood
Old July 25th, 2006, 12:32 PM   #8
Well dam you learn something new every day. Now off to order one of those!!
Old July 26th, 2006, 12:57 AM   #9
But these are all for telephoto stuff right? This rig still doesn't give us our prized wide angles capability?
Old July 26th, 2006, 09:12 AM   #10
A mm is a mm with these adapters. So if you use a 18mm Nikon lens, it would have the exact same FOV as setting the HD100 stock lens to 18mm.
The widest Nikon lens I know of is the 10.5mm fisheye, which of course would not be very wide on the 1/3" CCD.
The advantage is definitely for telephoto because you would have access to long lenses like 300mm.
If you want to match the FOV of 35mm, then you need a device like the mini35.
Tim Dashwood
Old July 31st, 2006, 10:24 AM   #11
Thanks for the help guys - this is what I've dug up so far:
P+S technic $8000 basic unit (old one on ebay at the moment, the 300 series going for around 3k last time i checked)
Redrock M2
Letus35
The adaptors that have the ground glass thingybob are the ones that give you narrower DOF, because the lens projects the image on the glass and then you capture it with your stock lens.
So if you use the Nikon lenses (or any other lenses) with just a bayonet mount it wouldn't really give a narrow DOF because its still using the 1/3" CCD. Is that correct?
I think it might be useful to use the telephoto lenses with the bayonets, say upwards of 120mm?
The bayonets are made by lesbosher.co.uk and also South London Filters here in the U.K (020 7735 1900) - or so I've been told.
