Confusion about "audio reference" on HD100 at DVinfo.net
Old July 18th, 2006, 01:08 AM   #1
I can't figure out what changing the audio refernce level actually "does".
Does it just move the little white dot on the meters and that's it?
Or does it boost the level or gain or something?
Thanks for the guidance.
Kelly
Kelly Ziolkoski is offline   Reply With Quote
Old July 18th, 2006, 09:00 AM   #2
You're right. It moves the little white dot.
Tim Dashwood
Old July 18th, 2006, 09:03 AM   #3
Capt. Quirk
And the little white dot signifies what?
www.SmokeWagonLeather.us
K. Forman is offline   Reply With Quote
Old July 18th, 2006, 09:33 AM   #4
Reference headroom. On analog equipment, the equivalent of "0" on your VU meter.
Most post houses use either -12dB or -20dB digital for reference tone.
Most sound recordists I've worked with will use -12dB if they are all digital (digital Nagra or DAT), or -20dB if they are using analog gear (Nagra or Shure analog mixer.) Some sound recordist swear by -20dB, but I find that their dialog tends to float or peak in the -30dB range, which is risky for "soft voices."
Tim Dashwood
Old July 18th, 2006, 10:01 AM   #5
Capt. Quirk
That made sense, thanks once again Tim!
