IDX versus AB - Page 2 at DVinfo.net
Old July 18th, 2006, 08:43 AM   #16
Capt. Quirk
Thanks Daniel, now I know what to call it. Is there just the one type of D tap, or are there several? If there are, I'm guaranteed to pick the wrong one!
www.SmokeWagonLeather.us
K. Forman is offline   Reply With Quote
Old July 19th, 2006, 12:04 AM   #17
Originally Posted by Daniel Patton
I also have that http://www.batteries4broadcast.com/hd100.htm battery for my IDX and agree, it's better than the IDX supplied ES-7's. And you get that second D-Tap connector on the battey itself.
Ok so the IDX es7 has the d-tap?
Old July 19th, 2006, 08:48 AM   #18
The es-7 battery itself does not, the IDX kit that came with the JVC/IDX combo has a D-Tap on the actual adapter that attaches to the camera, the es-7 then mounts to the adapter.
You end up with a second D-Tap on the after market battery that batteries4broadcast.com sells on the V-Mount style batteries. You can see it very well here:
http://www.batteries4broadcast.com/batt_type.htm
It's the battery in the middle (you can see the V mount configuration compared to the Gold Mount Style battery next to it on the left, typical to Anton Baur). The D-Tap connector is the dual plug black with gold female receptacles near the bottom of the battery.
I'm not claiming that you can run both D-Taps at the same time, my "guess" is that it depends on the load and of course the obvious effect the battery life. Better to ask around and get an experienced opinion on batteries / load first.
Hope this helps.
Our eyes allow us to see the world - The lens allows others to see the world through our eyes.
RED ONE #977
Daniel Patton is offline   Reply With Quote
Old July 19th, 2006, 09:12 PM   #19
Originally Posted by Brian Luce
is the power out plug for running things like firestore, on camera lightis? Does AB have that feature?
Yes it is the same power out as the mount has.
Gary Williams is offline   Reply
