HDV 720p down convert to NTSC 480 at DVinfo.net
Old July 14th, 2006, 10:37 AM   #1
whats the best way in FCP 5
Manny Rodriguez
Manny Rodriguez is offline   Reply With Quote
Old July 14th, 2006, 10:56 AM   #2
Right now, I'm using "Export Using Compressor", then selecting DVD Best quality 90min 2-pass.
It takes a while but the results look great on standard definition DVD.
Scott
Scott Jaco is offline   Reply With Quote
Old July 14th, 2006, 11:23 AM   #3
I am going back to tape, not DVD. Normaly I would just open a new sequence 720x480 and drop my 720px1280 in to it, is this the best way?
Manny Rodriguez
Old July 14th, 2006, 11:28 AM   #4
Export with Quicktime (do not use Export using compressor), select "Current settings", Audio and video, do NOT select "Make movie self contained".
This will generate a QT reference movie, drop it in compressor and select a suitable NTSC compression. Go for the highest quality. You can enter the cropping if you shot the footage in 16:9.
It's pretty surprising how nicely Compressor downconverts HD to SD.
Paolo http://www.paolociccone.com
Demo Reel
Paolo Ciccone is offline   Reply With Quote
Old July 14th, 2006, 12:09 PM   #5
thanks Paolo, you the man
Manny Rodriguez
Old July 16th, 2006, 10:41 AM   #6
I have heard that you should change the motion rendering to "fastest" instead of best for HDV, is that true?
Steve Benner is offline   Reply
