Is this normal?
Hi everyone. I am quite new to professional cameras. When I shoot during the night with the Hd100 and there is a source of light in the frame, a vertical stripe of light appears from that source. Is this a normal thing to happen or is there any setting to eliminate this problem? Hope I explained myself good enough.
That is a CCD flare, and is a byproduct of the way that CCDs scan. I know at least one HD100 has had some serious flare issues, so whether what you're seeing is "normal" depends on how big the flare is. It also depends on how bright the light source is. Frame grabs would be helpful.
If you close the iris down a little the streak becomes a star and looks much nicer.
Thats the way to deal with it. |
But how can you do that when you are filming with only available light and gain at 18db?!!
#5 |
At 18dB your picture is so grainy and fuzzy that a little bit of flare (or even a lot of flare) is the least of your worries. What are you shooting that you need so much gain? Lowering it will definitely reduce the problem.
#6 |
I was shooting a street during the night. This flare effect happened most when the street lights were against the dark sky. Ok maybe not really a must to set gain to 18db but definately I couldn't close the iris as suggested earlier in this thread. Thanks for answering to my problem
#7 |
a strong vertical line that comes from a light source is called Vertical Smear, its not flare. it has to do with the charge in the individual pixel overflowing into its neighbors above and below. its a charactoristic of CCD IT devices. Sony broadcast cameras usually have a rating for this at -120db or something, which means you won't ever see it except in the most extreme conditions. there are ways of taming the overflow charge, and basically the more expensive the CCD chip, the less it has the problem because they can afford to add the charactorics ( and perhaps some components ) to better deal with the overflow.
STeve Oakley |
#8 |
Thanks for your deep explanation steve. But is there something one can do to eliminate or at least lower this vertical smear?
#9 |
Frame so that the lights are not in the shot
Flag or Gaff off the direct light sources, Stop the lens down / Add more light, Buy a more expensive camera with better CCDs |
#10 |
You also might try a filter on the lens.
Also, you might try a piece of net over the lens. Might end up with beautiful stars or twinkly lights instead of streaks. |
#11 |
What filter can be used to reduce vertical smear?
#12 |
Any filter that would break up the light might do something desireable. Perhaps a star filter. Perhaps one of the smoothing filters that has a grid imbedded, or some other. I think this would be something to just try if you have some filters. Perhaps someone has specific experience that applies. I have just notice on my SD cameras that different filters affect highlights and "streaks" in different ways.
#13 | |
Tim Dashwood |
