Lanc? at DVinfo.net
Old June 24th, 2006, 03:38 AM   #1
Lanc?
Does this cam (HD100) have a lanc input?
Thanks-
Craig Terott is offline   Reply With Quote
Old June 24th, 2006, 03:41 AM   #2
lank hd 100
nope sure doesnt
Shawn Kessler is offline   Reply With Quote
Old June 24th, 2006, 09:42 AM   #3
Instead of LANC, the Fujinon lens features an 8-pin, pro-standard remote connector. This allows control over camera record function and zoom. Focus needs a separate, mechanical controller that interfaces with the lens barrel.
Earl R. Thurston, Stargate Connections Inc.
Made with GY-HD100: The Container Adventures: The Rescue
Earl Thurston is offline   Reply With Quote
Old June 24th, 2006, 10:22 AM   #4
Earl beat me to the description; the professional 8-pin interface is a much better way to go than LANC anyway. In short, LANC is not needed on this camera.
Old June 25th, 2006, 08:33 AM   #5
Occassionally I slow pan & slow zoom (as slow as humanly possible) while on a tripod. It's necessary for my style. I could still pull it off if there is no need to adjust focus for the particular shot but in event videography there are often unpredictable movents by subjects.
Old June 25th, 2006, 10:46 AM   #6
Craig extreme slow zooms are much better with a tripod lens pro-remote then Lanc could ever do. And the prices start around Lanc remotes. I got one for 250 Euro which works perfect.
Marc Colemont is offline   Reply With Quote
Old June 26th, 2006, 10:10 AM   #7
Marc
What model do you use?
Drew
Drew Curran is offline   Reply With Quote
Old June 26th, 2006, 10:27 AM   #8
Capt. Quirk
Marc- Does that do both zoom and focus?
www.SmokeWagonLeather.us
K. Forman is offline   Reply With Quote
Old June 26th, 2006, 10:51 AM   #9
The 8-pin lens connection is for zoom and record start only. Focus is a separate controller.
Old June 26th, 2006, 11:19 AM   #10
Capt. Quirk
I still think I used a focus w/zoom controller on a JVC a few years back. Problem is, I am getting to that age where it's getting really hard to tell what was real, and what was figment.
Old June 26th, 2006, 11:25 AM   #11
JVC America
Zoom & Focus Controls
All,
Here are the part numbers for the lens controls, assuming you are using the standard 16X lens:
Zoom Control - HZ-ZS13U
Focus Control - HZ-FM500
These are JVC items, available through authorized JVC Pro resellers.
Regards, Carl
Carl Hicks
JVC Professional Products Company
Carl Hicks is offline   Reply With Quote
Old June 26th, 2006, 01:33 PM   #12
Thank you all-
Old June 26th, 2006, 10:06 PM   #13
The remote focus control is rather like a cine follow focus, only with a cable so it can be mounted on a tripod arm instead of on the lens itself.
Stephan Ahonen is offline   Reply With Quote
Old June 27th, 2006, 02:04 AM   #14
That thing is awsome! I wish I had the 800 dollars to buy it.
Jonathan Nelson is offline   Reply
