#16 | |
#17 |
That's good to hear, Steve.... now I need to decide if I can wait that long. Thanks for the information.
#18 |
have u investigated the century optics options?
http://www.wizedot.com |
#19 |
Just a side issue, but moving subjects like dancers can really throw auto focus systems. I was filming a dance festival today with a Z1 and the focus took for ages to settle and could be way out.
Of course, since I was filming tight shots that were almost abstract in nature at times, this may not be a problem for you. However, even on wider shots the system was being thrown (sometimes 100M and infinity were being given as the focus distances) . BTW They were dancing against a black back drop. |
#20 |
Patricia,
I was at Cinegear in Los Angeles today and spoke to the Century Precision Optics people. I believe Century may have a solution for you. Century has several accessories that work on the HD100. First, they have a .8 wideangle converter, similar to the one from JVC. The only difference is that the century one is probably clearer in the corners than the JVC one. However, Century also has two wide angle adapters. These are not zoom through (like the converter is) but may be perfect for you. They go on the lens when it is set at its widest. With these you can probably set focus at infinity and get excellent focus in the distance range you will be dealing with. In any case, through some experimentation, it would be possible to find the right aperture, focus setting and distance range for what you need (and you can return the .8 converter if it is not useful): The are two WA adapters: .7X Wide Angle Adapter sold alone ($449.95): Part Number: WA-7X93 http://www.bhphotovideo.com/bnh/cont...ughType=search .7X .5X Wide Angle Adapter Set ($949.95) Part Number WA-7X5X http://www.bhphotovideo.com/bnh/cont...ughType=search The .7X has very little distortion -- the .5X has more -- though from what you said about what you have used, you would know how they look. Both of the Adapters require a step up ring for the HD100 ($77.50) Part Number FA-7X85 http://www.bhphotovideo.com/bnh/cont...ughType=search (All of the Part Numbers above have a "-00" on the end, but B&H drops this.) They said (all 3 of the Century reps) that these adapters have been perhaps their best seller the past few years. They work on many different cameras. Century also makes a super-fisheye adapter, a tele-converter (1.6X), a tele-extender (.2X), and acromatic diopters that work on the JVC HD100. The above links are to B&H. The Century website is www.schneideroptics.com However, when I looked up the camera on the site, the particular lens for the HD100 doesn't show up. However, I am looking at a sheet, Spring 2006, right now that shows the accessories listed by camera (JVC GY-100U. the Canon LX-H1, and the Panasonic AG-HVX200. The phone number for Century Schneider is: West Coast 818-766-3715 East Coast 631-761-5000 The Century adapters are very good and might be exactly what you need to get the HD100 to work in the situation you need, both close to the dancers while getting a full figure and in helping maintain focus when they move in and out within a reasonable range. |
#21 |
[Dupe Deleted]
#22 |
Interesting post, Brian. I have not seen what you did in my work so far, but perhaps the circumstances are different (I don't think I'm as close to the dancers as you were). But I'll watch for it.
Thanks for the information, Jack. I'm stopping by B&H today and will check out these options.. |
#23 |
Capt. Quirk
I'm still not 100% sure which lenses will work with this cam, but I have been shopping around on ebay. You would be surprised how many shorter Fuji lenses are for sale, for only a couple hundred. I'm just saying it might be worth while to look into. Me? I'm looking for longer lenses.
www.SmokeWagonLeather.us |
#24 |
Can't you just crank your tripod a little higher, to loose the tops of heads who wander in front of the lens. Then you could move a little further back to get the head to toe shot you want, with the extra headroom needed.
#25 | |
#26 | |
#27 |
Capt. Quirk
Just do a search on ebay. For instance, I saw a Fuji TV lens going for $120 or so. But, I'm still new to the lens game, and it might not have worked. Since I spent all my money, I don't dare go back yet.
#28 | |
Patricia Check out http://www.red-eye.tv/ for wide angle adapters for the HD100 Regards Drew |
#29 |
Y'know the canon xl2 has a 3.4mm 3x wide lens which is about the widest 1/3" lens available for under $8999. I know a guy (me) that might be willing to work out some kind of trade.
#30 | |
I wonder if this is comparable (qualitywise) to Century Optics one... anyone used this?
